Hi MrSilkworm
I assume you mean you have installed the Tapo-Camera Integration ?
Below is the url to this integrations “Project” Topic, where you can post questions related to this Integration
[Custom Component] Tapo: Cameras Control.
there is also links to the DOCS
Your C200 might only allow 1 connection, so you can’t access from both VLC and HA, at the same time, it’s either OR
For anyone to be able to help, you might also try to “structure” you question , stating what your do and where/when it fail, and if possible with relevant errors/connection entries from your logfile ( Setting/System/logs )
Also specify which Firmware & HW your Camera have
( As there is currently an ongoing issue in regards to some Versions , which is not “located” so far, and only some people seems to have problems, so far )
Scroll down to the bottom of the url i posted !, After you make sure you don’t have your cam “installed/exposed” elsewhere, before you try again ! ![]()
