So just to summarise the tapo P110 is now working fine with HA AND uses local polling? Is that right?
If I understand correctly you need the app to initially set it up but not after that?
Yes, I have it set up the way you described.
Hi guys,
today arrived my P110. I’ve set it up as described above.
You even can adjust the update interval of the energy readings to your needs.
Blocked the internet access via the router and so far everything is working as expected.
Nice product for around 15€.
Comperato ieri il Tapo P110 e configurato con Alexa. Mi serve solo per capire da remoto se in casa manca la corrente. Provato stamattina, ma non dà alcun messaggio. Suggerimenti? Grazie
