Hi, really good advice, it works straight away !!!
Hello…
I just migrated my home assistant to a new server platform.
installed mqtt, configure the user
I can see my devices in tasmota admin
however the tasmota plugin will not see the devices.
verified the IP address was updated on all clients (sonoff plugs)
tried the console and inserting the setoption19 1
anything else that could hold this up?
Hi every one. I did a new istalation of HA after a corrupt file im my sdcard and after that only 2 tasmotas switchs was reconizided bay de siten, both ar sistem 6.2.1 and i have somo wthi newer system
All Tasmotas wich do not conect has the same message conectio fail …rc 5.
I allredy check if user anpasswor are the sam im MQTT and tasmota.
I do have Tasmato integration no entities reconizied,
and I´m a log message Logger: aiohttp.server
Source: /usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py:405
First occurred: 18:38:05 (12 occurrences)
Last logged: 19:00:17
Error handling request
File “/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py”, line 334, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File “aiohttp/_http_parser.pyx”, line 551, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message=“Bad status line ‘Invalid method encountered’”
Ihave no idea if it has conection on this situation.
I alredy tryed everthing i know.
