Thanks for your work! Saved me spending money on another Sensibo device
The only issue I have is with supported_swing_list
My remotes data, see “SwingV”
13:05:47 MQT: tele/Irblast/RESULT = {"IrReceived":{"Protocol":"GREE","Bits":64,"Data":"0x5A0C605001420040","Repeat":0,"IRHVAC":{"Vendor":"GREE","Model":1,"Mode":"Dry","Power":"On","Celsius":"On","Temp":28,"FanSpeed":"Min","SwingV":"Auto","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"On","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
13:05:48 MQT: tele/Irblast/RESULT = {"IrReceived":{"Protocol":"GREE","Bits":64,"Data":"0x1A0C605002420040","Repeat":0,"IRHVAC":{"Vendor":"GREE","Model":1,"Mode":"Dry","Power":"On","Celsius":"On","Temp":28,"FanSpeed":"Min","SwingV":"Highest","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"On","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
13:05:49 MQT: tele/Irblast/RESULT = {"IrReceived":{"Protocol":"GREE","Bits":64,"Data":"0x1A0C605003420040","Repeat":0,"IRHVAC":{"Vendor":"GREE","Model":1,"Mode":"Dry","Power":"On","Celsius":"On","Temp":28,"FanSpeed":"Min","SwingV":"High","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"On","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
13:05:50 MQT: tele/Irblast/RESULT = {"IrReceived":{"Protocol":"GREE","Bits":64,"Data":"0x1A0C605004420040","Repeat":0,"IRHVAC":{"Vendor":"GREE","Model":1,"Mode":"Dry","Power":"On","Celsius":"On","Temp":28,"FanSpeed":"Min","SwingV":"Middle","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"On","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
13:05:51 MQT: tele/Irblast/RESULT = {"IrReceived":{"Protocol":"GREE","Bits":64,"Data":"0x1A0C605005420040","Repeat":0,"IRHVAC":{"Vendor":"GREE","Model":1,"Mode":"Dry","Power":"On","Celsius":"On","Temp":28,"FanSpeed":"Min","SwingV":"Low","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"On","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
13:05:52 MQT: tele/Irblast/RESULT = {"IrReceived":{"Protocol":"GREE","Bits":64,"Data":"0x1A0C605006420040","Repeat":0,"IRHVAC":{"Vendor":"GREE","Model":1,"Mode":"Dry","Power":"On","Celsius":"On","Temp":28,"FanSpeed":"Min","SwingV":"Lowest","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"On","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
Can the vertical swing position be implemented?
