Tasmota temperature scenes/automates dont work
Sonoffs basics and th10 flashed tasmota work normal in HA. Mqtt works normal.In HA i see sensors ds1820 temps and i can on/off the device
Temperatures scenes and automations dont trigger sonoffs to on/off.
Have to code some command in tasmota console?
  1. Post the yaml for your automations - using preformatted text tags.
  1. Note that triggers generally only trigger when the value they reference is crossed, that is: above: 10 only triggers when the value goes from 10 or below to above 10. If the value is already above 10 it will not trigger.
i know values triggers,but if not trigers by 20+ someting is not working. The HA dropdown scenec are the same like yaml. Why normal button triggers some another tasmo basic and not the temperature value by +20
Again: post the yaml for your automations - using preformatted text tags.
You won’t get any help if you don’t give us any details.
