YES
Thank you!
Now I just gotta figure out why the image doesnt load
Curious about this aswell⊠Iv happen to have this problem some times aswellâŠ
For the image link, are you using an internal IP address in the URL? Or are you using an external IP address or domain name? If itâs an internal IP, itâll only work when youâre on your home network or if youâre VPNâd in.
In my case, I host my tautuilli using my own subdomain.
Maybe take a look at the link to the image and see if the API key is correct? If you copy/paste it into a browser, you should see the image.
Good morning,
For me itâs more of a problem with the REST sensor.
it is well created, but the result is: error. I donât understand where the error is coming from, I need your help.
and this:
All my other tautulli sensors are correct.
Anything in the HA logs about it? Check the logs on startup, should have some sort of error message there (Iâd think).
nothing in the log, just template errors due to the problem with my sensor I suppose.
But I have this when starting Tautulli:
and I donât know where the problem comes from.
Try manually creating that link and pasting it into a browser. See if it returns JSON in the response?
For what reason, I donât know, my template works now. except that in the card, I donât have the photo. and there, on the other hand, I donât see where the problem comes from. To be sure:
in the template, is it the IP address of my HA server followed by: 8181? And for my card, it is the IP address of my streaming box (in this case, my Apple TV) followed by: 8181?
Iâm not making a mistake??
I have all the information about the film and server on the card, Iâm just missing the cover of the film. before my template problem, the card was correct, but since my problem, it has been impossible to recover my cover.
I found my problem, and itâs solved. (problem with my ip adress) Sorry for disturbing.
But I still have one question:
is it possible to make the card âbiggerâ?? If yes, how ?
Thank you.
What did you do?
Yes, It should be the IP address and port of where Tautuilli is hosted. The image and data all comes from Tautuilliâs API. Not from Plex or from your Apple TV. Glad you figured it out!
I have a maximum of 4 players who can use Plex at the same time, so 4 cards.
I would like to have 4 cards on my complete page of my dashboard in large size (so that the 4 take up the entire page) and not in small as it is at the moment. view the photo.
I tried this, but it doesnât change anything on my card.
I think youâre close. Instead of using Masonry, use âPanel (1 Card)â. For the card, choose a vertical stack, and then add in the auto entities card.
The Panel (1 Card) should take up the entire screen IIRC.
I am going crazy my card was working well for a while then something changed. I fixed it a bit but cant for life of me cant figure the last part.
Need that box to be transparent and have no out line on the barâŠ
card:
type: vertical-stack
card_param: cards
type: custom:auto-entities
filter:
exclude:
- state: unknown
include:
- device_manufacturer: Tautulli
entity_id: '*progress'
options:
entity: this.entity_id
type: custom:button-card
variables:
custom_fields:
picture:
card:
type: picture
image: |
return states['sensor.' + variables.entity.replace('_progress','').replace('sensor.','') + '_session_thumbnail'].state
card_mod:
style: |
ha-card {
box-shadow: 0;
#border-radius: 0;
#margin: 5px 0 0 -5px;
bar:
card:
type: custom:bar-card
entities:
- entity: this.entity_id
positions:
icon: 'off'
indicator: 'off'
minmax: inside
title: inside
value: inside
margin: 0px
height: 20px
color: '#e49f29'
return states['sensor.' + variables.entity.replace('_progress','').replace('sensor.','') + '_state'].state
card_mod:
style: |
ha-card {
--ha-card-background: none;
border: none;
box-shadow: none;
ha-card #states {
padding: 0;
bar-card-targe {
bar-card-currentbar, bar-card-backgroundbar {
border-radius: 5px;
left: 0;
bar-card-name {
margin-left: 3%;
text-shadow: 1px 1px 1px #0003;
intro: |
return "<b>" + states['sensor.' + variables.entity.replace('_progress','').replace('sensor.','') + '_progress'].attributes.friendly_name.replace(' Progress', '') + "</b> is currently watching..."
title: |
return states['sensor.' + variables.entity.replace('_progress','').replace('sensor.','') + '_full_title'].state
stream: |
return states['sensor.' + variables.entity.replace('_progress','').replace('sensor.','') + '_video_resolution'].state + " > " + states['sensor.' + variables.entity.replace('_progress','').replace('sensor.','') + '_transcode_decision'].state + " > " + states['sensor.' + variables.entity.replace('_progress','').replace('sensor.','') + '_stream_resolution'].state + ""
card_mod:
style: |
ha-card {
box-shadow: 0;
padding: 0;
margin: 0;
#border: 0;
ha-card #container {
margin: 5px 0 0 0;
#name {
display: none;
styles:
card:
- height: 100x
- padding: 4px
- background-color: transparent
custom_fields:
picture:
- margin: '-10px 0px -10px -5px'
- padding: '-10px 0px -10px -5px'
- border: '-10px 0px -10px -5px'
intro:
- text-align: start
- font-size: 15px
- color: '#e49f29'
- margin-bottom: 8px
user:
- text-align: null
- font-size: 15px
title:
- text-align: start
- font-size: 13px
stream:
- text-transform: capitalize
- text-align: start
- font-size: 13px
bar:
- font-size: 13px
- margin: 0px
- align: start
grid:
- grid-template-areas: >-
"picture x intro" "picture x title" "picture x stream" "picture
x bar"
- grid-template-columns: 1fr 15px 3fr 100px
Oh I think I GOT IT! any one see any code thats messed up?
Is it working for you? Anything look off in the display?
Is there anyway to display the friendly name of the user on the card rather than the username please?
Youâd probably have to use Jinja template logic to convert the name.
Great summery, i tried this but only gets an error when adding it and trying to restart HA⊠is there anyway you could maybe specify where i should add these codes? or maybe a step-by-step for a newbie like me to get a hang of it?
i tried to add everything to my configuration.yaml but thats when i got my error
Based on these steps, which part is giving you issues?
