Telegram: Double notifications EDIT: multiple automation actions
Hi.
I have a problem.
HASS sometimes send two or even three notifications.
Here is from my .yaml
 - alias: Garagedörren öppnad
     platform: state
     entity_id: binary_sensor.garaget_1_3
     to: 'on'
     service: notify.peter
       title: Garagedörren
       message: Har Öppnats.
 - alias: Garagedärren stängd
     platform: state
     to: 'off'
       title: Garagedörren
       message: Har stängts.
Quick fix I see here would be to add a “from” to your trigger state. I assume that for some reason the state is set to “on” multiple times and you trigger fires multiple times.
Greetings
Thanks.
I will try that.
After some quick testing it seems to work.
I guess this could help with all automation if someone get double.
Sorry for digging up an old thread.
But is this an issue with hass or expected behaivor?
I am trying to clean up my config yaml.
I changed from:
     platform: state
     to: 'on'
       title: Garagedörren
     platform: state
     to: 'off'
       title: Garagedörren
To
 - alias: Pling Garagedörr
     platform: state
       title: Pling.
       message: Garagedörren är nu {%- if is_state("binary_sensor.garaget_1_3", "on") %} öppen{% else %} stängd{%endif %}.
This will give me the same behaivor.
I guess this is a better way with less in the config and it will give me only one automation switch instead of two in the gui.
But this will bring my back to this problem. Sometimes double or triple actions from this automation.
I have other automation when i can’t have both from-state and to-state because in some automations i can’t predict what the from-state will be.
Other solutions on this problem?
It seems like a bug? isn’t it?
Did you ever find A solution for this? I Just now stumble puin the Same problem. I remover to and from state from my triggers to combine them. Now my automations fire two times in the logbook.
I have the same problem with HA CORE 0.108.2… Did you find any solution?
I didn’t find a real sollution. To be honest I just ignored the problem untill now and it seems to be gone for the most past. Still some doubles but most are gone.
