Tellstick addon broken after 0.60?
I’m running hassio on pi 2, removed everything except the ports to enable tellstick in yaml without success. There also is no error in our telldus configuration since it won’t even start with the example-config. Even though the service seems to connect to the hardware in the log. Reinstalled hassio from scratch two times with the same result. Is there any way to run tdtool from inside the hassio docker in resinos? That would be interesting.
