Telsa T-Smart Immersion Heater
No probs, do you want to share your python addon ? I only have NR installed for this device
Absolutely, just publishing it and making sure it works then I’ll put links/instructions here
So the first stab at a T-Smart addon is available. Here’s how to Install:
Navigate to Settings->Addons->Addon Store
  • Click the triple dots top right and “Repositories”
  • Add: “https://github.com/britkat1980/tsmart
  • It will then add TSmart as an addon for you to install
  • Install it then open the config tab and add the following info:
  • IP address of your TSmart
  • IP Address of the HA MQTT broker
  • add MQTT username and password if you use them
  • save config and then start the addon
The Addon will create a Climate device which will allow you to set the mode (using “presets”) and the temp using the usual cliamte controls.
Have a look and then let me know how you get on!
That’s brilliant thankyou.
Working great, only thing I suggest is you create one device with all the entities in it, rather than separate devices for all the sensors/controls etc
Good shout, That’s usually how I do it, but its not grouped them. I’ll update that now (also adding in a power sensor based off the heating state)
Great.
Just seen the climate device, brilliant !
version 0.8.8 is up and groups the entities into a single device and adds power entity
Great thanks, I’ll wait for the update to pop up in HA
Just installed, all seems to be working. Love the power sensor, I had a template sensor doing the same thing. Maybe need to add a power device_class so it has a unit of measurement ?
Thanks again
if you go into addon store and click check for updates it’ll show up quicker (I think it checks for updates once a day)
I never knew that thanks
It should have al that, I checked and an errant capital letter in the code meant it didn’t add it, 0.8.9 up now, which should have the device_class, and state_class
Yup, works perfectly
I’ve updated to version 0.9 which now has an entities for Error State, with attributes for each error as per the API docs. I assume it works, but don’t have any errors so can’t prove it out yet!
Great, many thanks. We’ll have to hope we never see any ! But its nice to have just in case
Very many thanks for this Mark.
Amanda’s node red flows were great but this is next level- makes the T-Smart super functional and it is very easy to set up.
I’ve just installed the Add on and configured it… but the logs are showing:
File “/app/TSmart/server.py”, line 173, in
return self.reconnect()
File “/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py”, line 1044, in reconnect
publishOutput(output)
File “/app/TSmart/server.py”, line 45, in publishOutput
HAMQTT.publish_discovery(tempoutput)
File “/app/TSmart/HA_Discovery.py”, line 83, in publish_discovery
sock = self._create_socket_connection()
File “/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py”, line 3685, in _create_socket_connection
client.connect(HAMQTT.MQTT_Address,port=HAMQTT.MQTT_Port)
File “/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py”, line 914, in connect
return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
File “/usr/local/lib/python3.10/socket.py”, line 824, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File “/usr/local/lib/python3.10/socket.py”, line 955, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -2] Name does not resolve
2022-10-07 10:12:21,609 TSmart_STARTUP - Starting UDP Server
2022-10-07 10:12:21,610 root - Starting the MQTT Client…
2022-10-07 10:12:21,750 - root [CRITICAL] Inside server.py
2022-10-07 10:12:21,750 - root [CRITICAL] UDP server up and listening
File “/app/TSmart/mqtt_client.py”, line 82, in
client.connect(MQTT_Address,port=MQTT_Port)
File "/usr/local/lib/python3.10/site-packages/paho/mqtt/client
Any thoughts? I thought that I had everything correct (double checked too - IP address, mqtt user and p/w) but clearly something is wrong…
Did you do anything extra between the three elements in the instructions? * IP address of your TSmart
No that was it I think.
have you tried MQTT explorer and make sure the messages are appearing there ?
Result! my MQTT was in the wrong case!!! perfect… up and running…
Amazing work Mark, thank you for spending the time on this and publishing for the community to benefit!
