If you are talking about your discord link, it leads to nothing (and I am a member of the esphome discord).
Right⦠Hmmā¦
Well I used the ācopy link to messageā Discord feature and just double checked it is correct. So not sure how else to do it.
Seems to work for me.
Searching Discord for āDelta sensorā will also bring it upā¦
I have manage to solve my problem with a helper and two automations.
First of all I create a input_number sensor.
{{ states('input_number.attic_shower_max_temperature') }}
When temperature is rising the following automation is running, sets the bathroom sensor to occupied, plays a TTS notification and some bathrooom music with Alexa.
alias: Bathroom is occupied (ON)
description: When pipe's temperature above 25°C turn on occupancy switch
- platform: numeric_state
entity_id: sensor.attic_hot_water_pipe
above: 25
condition:
- condition: state
entity_id: input_boolean.attic_shower_is_occupied
state: "off"
data: {}
- service: persistent_notification.create
title: INFORMATION
message: |
Someone has just started to have a shower at {{ states('sensor.time') }}.
- service: notify.mobile_app_sm_g980f
title: INFORMATION
message: Someone is having a shower...
- if:
- condition: state
entity_id: group.attic_wc
state: "on"
then:
- service: media_player.volume_set
volume_level: 1
entity_id: media_player.bathroom
- service: notify.alexa_media
- media_player.bathroom
type: tts
message: >-
Hmmm. I am sensing that someone is having a shower...Here are some
songs to sing in the shower!
alias: "Notifications: Send a notification with alexa_media (bathroom)"
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- service: media_player.select_source
source: Bathroom
entity_id: media_player.spotify_makis_solomos
- service: media_player.shuffle_set
shuffle: true
- service: media_player.play_media
media_content_type: playlist
media_content_id: >-
https://open.spotify.com/playlist/37i9dQZF1DWSqmBTGDYngZ?si=d31f0e30a8f14ede
mode: single
At the same time, another automation is running which saves pipeās temperature to the helper.
alias: Bathroom is occupied save temperature to helper
description: ""
value_template: >-
{{ states('sensor.attic_hot_water_pipe') >
condition: []
- service: input_number.set_value
value: "{{ states('sensor.attic_hot_water_pipe') }}"
entity_id: input_number.attic_shower_max_temperature
mode: single
Finally, a final automation checks the temperature and if is falling it consider that the shower is completed:
alias: Bathroom is occupied (OFF)
description: ""
- platform: time_pattern
minutes: /15
condition:
- condition: state
state: "on"
- condition: template
value_template: >-
{{ ((states('sensor.attic_hot_water_pipe') | float -
states('input_number.attic_shower_max_temperature') | float) *-1) > 3 }}
- service: input_boolean.turn_off
data: {}
message: |
Shower is completed {{ states('sensor.time') }}.
title: INFORMATION
- service: media_player.media_stop
data: {}
mode: single
It works flawlessly!!!
(please note that I had to reset the max. temperature helper so it will run again next day)
alias: Bathroom is occupied reset max. temperature
description: ""
below: 20
condition:
- condition: state
state: "off"
value: 21
mode: single
Why isnāt this the trigger?
If this is the trigger then it will trigger immediately as the temperature drops when shower is occupied, not sure I understand why you need to wait for 15 minutes
Because using a numeric state trigger doesnāt work always.
If it pass through the threshold it wonāt trigger untill it goes up and down againā¦
I agree that this is the right trigger to fire but I couldnāt make it to work.
It didnāt fire always with (pipeās temperature - max. temperature) < 3
And If I change the row of sensors e.g. (max - pipe) will also trigger when temperature rises ⦠** see above automation. (because it will give a negative number which is < 3)
So it will switch off the occupancy sensor before it starts ā¦
Hope I can make myself clear here ā¦
But why donāt you replicate it? ā¦See yourself the barries that make me choose the time patern trigger instead.
No⦠as a template trigger, just as your condition.
I have several template triggers not specifically like this but they all work fine.
I think I would not stick to these static temperature values. I think a more universal way would be (I believe @Mahko_Mahko mentioned that) to just use the temperature gradient / difference over time.
Of course it depends on how you define the window size for your samples.
But the idea is:
- any temperature rise (no matter which the āstarting temperatureā was) will indicate that someone is showering (or anything else that uses warm water).
- any temperature drop indicates, that warm water usage has been stopped.
So the logic would be (pseudocode):
delta_T = new_sample - old_sample
if delta_T > threshold1: warm_water_use = true
else if delta_T < threshold2: warm_water_use = false
And because someone might take a break while showering (maybe because his/her hair conditioner needs some time) your automation trigger to determine if the shower is really in use or not could observe the duration of how long warm_water_use is true or false.
Something like:
if warm_water_use is true for > delay1: shower_occupied = true
else if warm_water_use is false for > delay2: shower_occupied = false
You only have to define (or evaluate) a reasonable sampling time, the thresholds to determine if warm water is used or not, and the delays to say if the shower is really occupied or not.
This would be universal and flexible.
Greetings!
This is exactly what I suggested in post 7. Use derivative, trend or statistics sensor to know where the data is heading.
But by some reason he uses input number and automations.
Sry, I have missed that one
But nice to know that we share a basically same idea
Can we please have some real code for ESP ???
because maybe HE is not that expert user like you ⦠![]()
and maybe YOU should read more carefully. ![]()
Please read my post #13
Trend and derivative sensors didnāt work for me .
The only thing you said was:
I didnāt reply to it before since it looked like an excuse.
1 If your sensor is ESP based then set the update interval.
2 if the sensor does not update frequently enough for a derivative sensor then why would work creating a manual derivative sensor?
3 if your automation triggers every 15 minutes then how can speed be an issue at all?
4 your automation:
description: ""
value_template: >-
condition: []
mode: single
Triggers in the exact same rate as a derivative, trend or statistics sensor because itās based on the same sensor updating.
Not sure exactly how these sensors did not work for you since they are based on the same entity.
The only difference is that my suggestion was to trigger on a drop in this sensor of a certain degree. I canāt answer on what that degree is because I donāt have something similar.
My answer on you suggestion was:
Humidity sensor is not an option. Of course I already have one, but it is not always accurate as I live at an island and the humidity is problem ⦠Sometimes humidity at the bathroom is too high even though nobody is using the shower! I use it among with trend and derivative sensors but not always accurate in my situation.
I have never talked about a humidity sensor.
