Template cover - how to get position in set_cover_position
Hi @InToSSH , I have the same problem, did you solved it.
If you have the same problem, then you’re using the wrong variable or your template is bad. No help can be provided without your configuration. It’s also best to start a new topic. When you revive old topics like this, they fall off the front page quickly unless there’s people watching the thread. This is why everyone’s question after @InToSSH’s question has gone unanswered.
Hello @drphungky and @Dreamray
I am really sorry about the delay and I know it’s probably too late, but I wanted to respond in case somebody else needs this in the future. I got caught up with a project and didn’t have much time to play with HA or monitor this forum.
This is the currently working config I am using for tilt:
  covers:
    living_room_cover_tilt:
      friendly_name: "Living Room Cover Tilt"
      position_template: "{{ state_attr('cover.living_room_cover', 'current_tilt_position') | int }}"
      availability_template: "{% if is_state('cover.living_room_cover', 'unavailable') %} false {% else %} true {% endif %}"
      device_class: blind
      open_cover:
        service: cover.open_cover_tilt
          entity_id: cover.living_room_cover
      close_cover:
        service: cover.close_cover_tilt
      set_cover_position:
        service: cover.set_cover_tilt_position
        data_template:
          tilt_position: "{{position}}"
I think I gave up on getting Google to work with tilting the blinds. Weirdly, it did work for a while, but not sure if it was my current settings or not. Maybe google home was quietly testing tilt functionality for exposed blinds, who knows. I ended up abandoning my discoverable over MQTT microcontroller and did the whole thing in ESPHome. I don’t use tilt in this file anymore, but last I recall it did work in Home Assistant - I just took the buttons off the dashboard so it matches the remote (which as I mentioned above, only has up, down, and stop buttons - tilt is just down all the way, and stop doubles as “favorite” which is closed.) Full config is below in case anyone wants to steal the format:
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid:
  password:
  ap:
    ssid: "Downstairs Esp Fallback Hotspot"
    password:
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
# Devices
remote_transmitter:
  pin: D7
  carrier_duty_percent: 100%
switch:
#Living Room Blinds
    name: "Living Room Blinds Up Switch"
    turn_on_action:
      - remote_transmitter.transmit_raw:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 350, -700, 350, -700, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
    name: "Living Room Blinds Down Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 700, -350, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
    name: "Living Room Blinds Stop Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
#Dining Room Blinds
    name: "Dining Room Blinds Up Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
    name: "Dining Room Blinds Down Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
    name: "Dining Room Blinds Stop Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
#Guest Room Blinds
    name: "Guest Room Blinds Up Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
    name: "Guest Room Blinds Down Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
    name: "Guest Room Blinds Stop Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
#East Kitchen Blinds
    name: "East Kitchen Blinds Up Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 350, -700, 350, -700, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
    name: "East Kitchen Blinds Down Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 700, -350, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
    name: "East Kitchen Blinds Stop Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
#Kitchen Sink Blinds
    name: "Kitchen Sink Blinds Up Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
    name: "Kitchen Sink Blinds Down Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
    name: "Kitchen Sink Blinds Stop Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
#Master Bedroom Blinds
    name: "Master Bedroom Blinds Up Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 700, -350, 350, -700, 1750]
          repeat:
            times: 8
            wait_time: 0s
      - delay: 340ms
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 700, -350, 350, -700, 1750]
          repeat:
            times: 8
            wait_time: 0s
      - delay: 390ms
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
    name: "Master Bedroom Blinds Down Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 1750]
          repeat:
            times: 8
            wait_time: 0s
      - delay: 340ms
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 1750]
          repeat:
            times: 8
            wait_time: 0s
      - delay: 390ms
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
    name: "Master Bedroom Blinds Stop Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
#Kids Room Blinds
    name: "Kids Room Blinds Up Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 700, -350, 350, -700, 1750]
          repeat:
            times: 8
            wait_time: 0s
      - delay: 340ms
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 700, -350, 700, -350, 350, -700, 1750]
          repeat:
            times: 8
            wait_time: 0s
      - delay: 390ms
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
    name: "Kids Room Blinds Down Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 1750]
          repeat:
            times: 8
            wait_time: 0s
      - delay: 340ms
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 1750]
          repeat:
            times: 8
            wait_time: 0s
      - delay: 390ms
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
    name: "Kids Room Blinds Stop Switch"
    turn_on_action:
          code: [3850, -2450, 1750, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 700, -350, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 350, -700, 700, -350, 350, -700, 350, -700, 700, -350, 700, -350, 700, -350, 1750]
          repeat:
            times: 8
            wait_time: 0s
    internal: TRUE
cover:
    name: "Living Room Blinds"
    open_action:
      - switch.turn_on: livingRoomBlindsUp
    close_action:
      - switch.turn_on: livingRoomBlindsStop
    stop_action:
    tilt_action:
      - lambda: |-
          if (tilt <= 0.5) {
            id(livingRoomBlindsStop).turn_on();
          else {
            id(livingRoomBlindsDown).turn_on();
    assumed_state: true
    device_class: blind
    name: "Dining Room Blinds"
    open_action:
      - switch.turn_on: diningRoomBlindsUp
    close_action:
      - switch.turn_on: diningRoomBlindsStop
    stop_action:
    tilt_action:
      - lambda: |-
          if (tilt <= 0.5) {
            id(diningRoomBlindsStop).turn_on();
          else {
            id(diningRoomBlindsDown).turn_on();
    assumed_state: true
    device_class: blind
    name: "Guest Room Blinds"
    open_action:
      - switch.turn_on: guestRoomBlindsUp
    close_action:
      - switch.turn_on: guestRoomBlindsStop
    stop_action:
    tilt_action:
      - lambda: |-
          if (tilt <= 0.5) {
            id(guestRoomBlindsStop).turn_on();
          else {
            id(guestRoomBlindsDown).turn_on();
    assumed_state: true
    device_class: blind
    name: "East Kitchen Blinds"
    open_action:
      - switch.turn_on: eastKitchenBlindsUp
    close_action:
      - switch.turn_on: eastKitchenBlindsStop
    stop_action:
    tilt_action:
      - lambda: |-
          if (tilt <= 0.5) {
            id(eastKitchenBlindsStop).turn_on();
          else {
            id(eastKitchenBlindsDown).turn_on();
    assumed_state: true
    device_class: blind
    name: "Kitchen Sink Blinds"
    open_action:
      - switch.turn_on: kitchenSinkBlindsUp
    close_action:
      - switch.turn_on: kitchenSinkBlindsStop
    stop_action:
    tilt_action:
      - lambda: |-
          if (tilt <= 0.5) {
            id(kitchenSinkBlindsStop).turn_on();
          else {
            id(kitchenSinkBlindsDown).turn_on();
    assumed_state: true
    device_class: blind
    name: "Master Bedroom Blinds"
    open_action:
      - switch.turn_on: masterBedroomBlindsUp
    close_action:
      - switch.turn_on: masterBedroomBlindsStop
    stop_action:
    tilt_action:
      - lambda: |-
          if (tilt <= 0.5) {
            id(masterBedroomBlindsStop).turn_on();
          else {
            id(masterBedroomBlindsDown).turn_on();
    assumed_state: true
    device_class: blind
    name: "Kids Room Blinds"
    open_action:
      - switch.turn_on: kidsRoomBlindsUp
    close_action:
      - switch.turn_on: kidsRoomBlindsStop
    stop_action:
    tilt_action:
      - lambda: |-
          if (tilt <= 0.5) {
            id(kidsRoomBlindsStop).turn_on();
          else {
            id(kidsRoomBlindsDown).turn_on();
    assumed_state: true
    device_class: blind
This is what I did in ESPHome, which is running on Shelly 2.5, which is connected directly in place of my previous up/down buttons on my blind. This exposes the cover with tilt in my HA, then I separated the tilt to separate cover using the code above and I am using it as a separate cover in Google Home to control the tilt with my voice.
globals:
  - id: cover_moving #This is for the HW buttons to determine if a press should stop the blind or start moving it (this could probably be done without this var by reading id(time_cover).current_operation)
    type: bool
    initial_value: "0"
cover:
  - platform: time_based # Time based cover to track the position of the blind based on the time (unfortunatelly this doesn't support tilt)
    name: ${device_name} - Time Cover
    internal: True
    has_built_in_endstop: True # The controller in my blind automatically stops the motor in it's endpoints, this is set to True to be able to synchronize the zero position based on time with the actual position when the blind is either fully closed or open
                               # The power meter in the Shelly2.5 is then used to determine when the blind has stopped, sending a "cover.stop" action to this cover.
    open_action:
      - globals.set:
          value: "true"
      - script.execute: detect_endpoint
      - switch.turn_off: motor_down
      - switch.turn_on: motor_up
    open_duration: 54sec # Set the correct time for your specific blind
    close_action:
      - globals.set:
          value: "true"
      - switch.turn_off: motor_up
      - switch.turn_on: motor_down
    close_duration: 53sec # Set the correct time for your specific blind
    stop_action:
      - globals.set:
          value: "false"
      - script.stop: detect_endpoint
  - platform: template # Template cover which synchronizes position with the time_cover, but also supports tilt.
    lambda: |-
      if (id(template_cover).current_operation != id(time_cover).current_operation)
        id(template_cover).current_operation = id(time_cover).current_operation;
      return id(time_cover).position;
    has_position: true
    assumed_state: True
    open_action:
      - cover.open: time_cover
    close_action:
      - cover.close: time_cover
    stop_action:
      - cover.stop: time_cover
    position_action:
      - cover.control:
          position: !lambda |-
            return pos;
    tilt_action:
      - lambda: |-
          if (tilt == 1) {
            auto call1 = id(time_cover).make_call();
            call1.set_command_open();
            call1.perform();
            delay(1000);
            auto call2 = id(time_cover).make_call();
            call2.set_command_stop();
            call2.perform();
          } else if (tilt == 0) {
            call1.set_command_close();
            call1.perform();
            delay(1000);
            call2.perform();
          } else {
            if (tilt > 0.5) {
              call1.perform();
              delay(1000);
              call2.perform();
              delay(500);
              auto call3 = id(time_cover).make_call();
              call3.set_command_close();
              call3.perform();
              delay(1000 - (tilt*1000) + 50);
              auto call4 = id(time_cover).make_call();
              call4.set_command_stop();
              call4.perform();
            if (tilt <= 0.5) {
              call1.perform();
              delay(1000);
              call2.perform();
              delay(500);
              call3.set_command_open();
              call3.perform();
              delay(tilt*1000 + 200);
              call4.perform();
          id(template_cover).tilt = tilt;
          id(template_cover).publish_state();
script:
  - id: detect_endpoint # Used to detect the endpoint of the blind based on the power draw, the blind automatically stops in it's endpoints, this might not be needed, but I don't like the idea of leaving the relay on when "has_built_in_endstop" is used on the cover.
    then:
      - delay: 5sec
      - wait_until:
          sensor.in_range:
            below: 20
      - wait_until:
          sensor.in_range:
            below: 20
      - cover.stop: template_cover
switch:
  - platform: gpio
    pin: 4
    name: ${device_name} - Motor UP
    interlock: [motor_down]
    interlock_wait_time: 100ms
    internal: true
    restore_mode: always off
  - platform: gpio
    pin: 15
    name: ${device_name} - Motor DOWN
    interlock: [motor_up]
    internal: true
binary_sensor:
  - platform: gpio # Physical button on the wall to move the blind UP
    pin: 5
    name: ${device_name} - Button UP
    on_press:
      then:
        - if:
            condition:
              lambda: 'return !id(cover_moving);'
            then:
              - cover.open: template_cover
    on_click:
      - min_length: 1ms
        max_length: 999ms
        then:
  - platform: gpio # Physical button on the wall to move the blind DOWN
    pin: 13
    name: ${device_name} - Button DOWN
    on_press:
      then:
        - if:
            condition:
            then:
              - if:
                  condition:
                    binary_sensor.is_off: ha_covers_blocked
                  then:
                    - cover.close: template_cover
    on_click:
      - min_length: 1ms
        max_length: 999ms
        then:
  - platform: homeassistant
    name: ${device_name} - HA Covers Blocked
    entity_id: input_boolean.covers_blocked
    name: ${device_name} - HA UP
    entity_id: input_boolean.momentary_up
    internal: true
    on_press:
      then:
        - if:
            condition:
            then:
    on_click:
      - min_length: 1ms
        max_length: 999ms
        then:
    name: ${device_name} - HA DOWN
    internal: true
    entity_id: input_boolean.momentary_down
    on_press:
      then:
        - if:
            condition:
            then:
    on_click:
      - min_length: 1ms
        max_length: 999ms
        then:
  - platform: ade7953
    voltage:
      name: ${device_name} - Voltage
    current_a:
      name: ${device_name} - Current Down
      internal: True
    current_b:
      name: ${device_name} - Current Up
      internal: True
    active_power_a:
      name: ${device_name} - Power Down
    active_power_b:
      name: ${device_name} - Power Up
      filters:
        - multiply: -1
    update_interval: 3s
This worked perfectly! Thank you!
I have the Z-Wave iBlinds 3 which work great within Home Assistant but where exposed to Google Assistant as unavailable.
I installed your template and after a quick HA restart, I had working blinds in Google Home app/Google Assistant.
For reference, here is what the state and attributes of the original iBlinds entity (top) looks like compared to the newly created cover template (bottom):
Hello @InToSSH, I am trying to find a solution about a similar issue. Can you look at the coding below and find a solution for me?
In the smart curtain system I have been using for a long time, I can only raise and lower the curtain. But when the power is cut off, I want the motor to remember where it left off and continue. Plus I want to be able to raise and lower the curtain to the desired %. Can you help me with this?
My tools in the curtain system.
Nema 17 stepper motor
A4988 motor driver board
Esp32-wroom-32 programming board
LM2596 Regulator
3 buttons
DC 12v adapter
Self-prepared coding
substitutions:
  devicename: yatakodasiperde
  mystepper: my_stepper
  speed: 1200 steps/s
esphome:
  platform: ESP32
  board: nodemcu-32s
  libraries:
    - EEPROM
# Enable logging
logger:
  level: DEBUG
  logs:
    esphome.core: DEBUG
    esphome.components: DEBUG
api:
  services:
  - service: control_stepper
    variables:
      target: int
    then:
      - stepper.set_target:
          target: !lambda 'return target;'
ota:
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
  manual_ip:
    static_ip: 192.168.1.69
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    dns1: 192.168.1.1
  ap:
    ssid: "Akilli Perde"
    password: "password"
captive_portal:
web_server:
  port: 80
stepper:
  - platform: a4988
    step_pin: GPIO19
    dir_pin:
      number: GPIO18
      inverted: true
    max_speed: ${speed}
    acceleration: inf
    deceleration: inf
  - platform: wifi_signal
    name: "WiFi Sinyali yatakodasiperde"
    update_interval: 60s
text_sensor:
  - platform: wifi_info
    ip_address:
      icon: "mdi:ip"
      name: "IP yatakodasiperde"
    ssid:
      name: "SSID yatakodasiperde"
      icon: "mdi:access-point-network"
    bssid:
      name: "BSSID yatakodasiperde"
output:
  - platform: gpio
    pin: GPIO21
    inverted: true
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO12
      mode: INPUT_PULLUP
      inverted: true
    on_press:
      then:
        - output.turn_on: enable_pin
        - if:
            condition:
              lambda: 'return id($mystepper).current_position != 35000;'
            then:
                  target: 35000
              - delay: 1ms
              - while:
                  condition:
                  then:
                    - delay: 1ms
        - delay: 1ms
        - output.turn_off: enable_pin
  - platform: gpio
    pin:
      number: GPIO13
      mode: INPUT_PULLUP
      inverted: true
    on_press:
      then:
        - if:
            condition:
              lambda: 'return id($mystepper).current_position != 0;'
            then:
                  target: 0
              - delay: 1ms
              - while:
                  condition:
                  then:
                    - delay: 1ms
        - delay: 1ms
        - cover.template.publish:
            position: !lambda 'return id($mystepper).current_position;'
  - platform: gpio
    pin:
      number: GPIO14
      mode: INPUT_PULLUP
      inverted: true
    on_press:
      then:
            target: !lambda 'return id($mystepper).current_position;'
cover:
    open_action:
      - if:
          condition:
          then:
                target: 35000
            - delay: 1ms
            - while:
                condition:
                then:
                  - delay: 1ms
      - delay: 1ms
    close_action:
      - if:
          condition:
          then:
                target: 0
            - delay: 1ms
            - while:
                condition:
                then:
                  - delay: 1ms
      - delay: 1ms
    stop_action:
