How do I trigger calling this endpoint in my template? And how do I store e.g. the display_name property as my status and the other JSON data as attributes?
Here’s my approach so far:
template:
- sensor:
- name: "my location"
state: >
set url = "https://locationiq.com/v1/reverse.php?key=my_api_key&lat="
+ state_attr('device_tracker.location','latitude') | string
+ state_attr('device_tracker.location','longitude') | string
+ "&format=json"
# do something with the {{ url }}
Hi! Expecting sensor.my_location to hold the value of JSON attribute display_name as the status and as the attributes some/all of the API attributes.
Thanks for your example. That one is based on a fixed scan interval. Can I instead trigger it every time the lat/lon attributes of the device_tracker.location change (=when the entity device_tracker.location is updated)?
@Hellis81 I guess I don’t understand your question which I tried to explain in the original post and in reply to your original question. I’ll try to explain in more detail.
For my other car I have set a custom sensor that contains the geocoded address label (coming from another entity): sensor.location_car1 contains status e.g. “my address”.
Trying to achieve something similar for my car which only returns lat+lon (which means I need to perform a reverse geocoding before I can set the sensor state).
My current implementation
helper: input_text.location_car which contains the reverse geocoded address
(empty) script: reverse_geocode (with service_data: lat+lon using the state attributes from the device_tracker)
Node-RED flow: listen for event service reverse_geocode, call the reverse geocode endpoint, set the input_text.location_car helper
automation: called when the latitude attribute of the device tracker changes, calls the (empty) script which triggers the Node-RED flow
But this feels like using too many steps, plus I prefer using a real sensor and not a helper.
The automation:
alias: reverse geocode latlon
description: calls script (caught by Node-RED) which sets input_text.location_car
- platform: state
entity_id: device_tracker.location
attribute: latitude
condition: []
- service: script.reverse_geocode
lat: "{{ state_attr('device_tracker.location','latitude') }}"
lon: "{{ state_attr('device_tracker.location','longitude') }}"
So you expect us to read what the endpoint returns instead of you just telling us?
Again, why should I have to read what the API does?
In my opinion a proper question should include what the API returns so that we can help you without reading through an API documentation and/or create an account for said API.
Use a state automation with noting filled in to or from.
Action homeassistant.update_entity (or similar) on the rest API sensor.
This depends on what the API returns. There is no generic answer as far as I know
@Hellis81 let’s not argue, we’re just having trouble understanding each other.
The custom component Places is indeed useful,
and I think I now understand your 2nd suggestion (which expands on @pergola.fabio 's original response):
REST sensor: calls the reverse geocode endpoint, using the lat+lon from device_tracker as parameters (note: default scan_interval is 30 seconds, can use large one e.g. 86400 because we only want to run it triggered by the automation)
automation: if state (or attribute) of our device_tracker changes then run service homeassistant.update_entity for the REST sensor
I ended up using that approach, using positionstack as the reverse geocoding provider.
If someone else wants to do the same thing, here is my complete (working) result.
In short: device_tracker.location contains the lat+lon we’re interested in, and sensor.location_car is the REST sensor that is set to the reverse geocoded address label.
sensor location_car:
- platform: rest
value_template: "{{ value_json.data[0].label }}"
json_attributes_path: "$.data[0]"
json_attributes:
- label
- type
- confidence
- distance
- name
- street
- number
- postal_code
- region
- region_code
- locality
- neighbourhood
- country
verify_ssl: false
scan_interval: 86400 # 1 day -- preferred: home_assistant.update_entity
resource_template: >
"http://api.positionstack.com/v1/reverse?access_key=MY_API_KEY&limit=1&query="
and my automation:
alias: reverse geocode latlon car
- platform: state
attribute: latitude
condition: []
entity_id: sensor.location_car
