hey David, Maybe also +1 on the Fr for the toggle
Is it possible for the secondary info to have multi line output? I canāt seem to inject any kind of of new line character in the template.
anyone else seeing issues on the template-entity-row card in HA115.
I am using this on templates built by Python at startup, which apparently is not very well digested (too late for the engine, causing the full startup to take a very long time.) either by HA, or by the T-e-r card.
thereās a fix for HA planned for several of these timing issues, maybe T-e-r card would need some extra attention
Iām trying to get template-entity-row to show localized state which in my case I think should be like this:
state: "_(state.binary_sensor.door.{{states('binary_sensor.balkongdorr_sovrum_tmpl')}})"
which shows up like this:
ā¦not really the way I expected.
But this actually works:
state: "_(component.binary_sensor.state.door.{{states('binary_sensor.balkongdorr_sovrum_tmpl')}})"
Am I doing something wrong (that just accidentally happened to work) or has something changed and the docs should be updated?
having made this verbose template:
- type: custom:auto-entities
card:
type: entities
title: Person address trackers
filter:
include:
- entity_id: person.*_address
options:
type: custom:template-entity-row
secondary: >
{{state_attr(config.entity,'road')}} {{state_attr(config.entity,'house_number')}},{{state_attr(config.entity,'postcode')}} {{state_attr(config.entity,'town') if state_attr(config.entity,'town') else state_attr(config.entity,'city')}}, {{state_attr(config.entity,'country')}}
I suppose there could be a better wayā¦
but, donāt see it right now, so turning to the community here.
Please have a look? thanks!
Is this HACS add-in still working?
I just get ācustom element doesnāt exist: template-entity-rowā
Iāve installed it using up-to-date HACS (1.9.0) whilst running 2020-12-1 and also restarted HA.
I am using it with no problems
Maybe it is the act of installing it in the current HA version.??
I got round it by using card-templater instead.
I have been using it for ages with no issues and now in 2021.1.0b1 and all is goodā¦
Thanks for the prod David,
I typed my card definition in long-hand rather than a cut and paste and it works !
Hello Thomas,
thanks for this plugin.
Can i ask for you help for something similar:
I try to get this:
the problem i have is that i canāt manage to get the title to work with template as you do in your post because i use a different type of entity (i want the time to be the bigger as possible).
i try with this code:
type: entity
entity: sensor.time
but i get:
two questions:
I try to mimic secondary_info: last-changed
from a normal in entity
secondary: "{{ relative_time(states[config.entity].last_changed) }}"
works fine but isnāt translated in the UI.
any wordaround?
2nd: when using card_mod
is there a way to color just the icon and the entity value?
This gives me a full colored row and icon:
card_mod:
style: |
{% if states(config.entity) | float > 23 %}
:host {
--paper-item-icon-color: red;
color: red
{% elif states(config.entity) | float < 21 %}
:host {
--paper-item-icon-color: blue;
color: blue
{% else %}
:host {
--paper-item-icon-color: green;
color: green
{% endif %}
Thanks =)
Can I pass attribute values to a script on tap_action with this?
Is it work with Banner Card? Iāve tried to add it, but the card shows nothing.
Same entry works fine for built-in Entities Card.
type: custom:banner-card
heading:
- Bedroom
background: url("/local/images/bedroom.jpg")
entities:
- entity: sensor.zwave_temp_bedroom_air_temperature
- entity: sensor.zwave_temp_bedroom_humidity
- entity: switch.zwave_plug_bedroom
- type: custom:template-entity-row
name: AC Power Rounded
state: '{{ states.sensor.zwave_plug_ac_electric_consumed_w.state | round }}'
Can anyone help?
Just started learning this nice card, have a question about localized strings:
secondary: |
{{ '_(ui.common.previous)' }}
icon: mdi:car
The result for the āsecondaryā is āBackā.
Is it possible to do any operations with the localized string?
For example, I need smth like this:
{{ '_(ui.common.previous)'.lower() }}
to convert āBackā to ābackā.
But it does not work since the ā_()ā is resolved after the template works.
Can this be combined with the slider-entity-row?
Wondering if anyone had an experience with nested attributes? Iāve got myself stuck here:
This worksā¦
- entity: sensor.rpi_monitor_piholeprimary
state: |
{{ states.sensor.rpi_monitor_piholeprimary.attributes['memory']['size_mb']}}
But this doesnātā¦
state: |
{{ states.config.entity.attributes['memory']['size_mb']}}
Could be argued that I should just use it the way it works, but this forms part of a template using the decluttering card which Iām reusing. The entity is being passed in by the decluttering card (proven to work) so the use of config.entity is key for me.
If I just try to get the memory object that works fine both ways, just canāt get to the attributes of the memory.
Any pointers or suggestions really appreciated. Thanks!
if size_mb is part of the attributes memory object, you might want to try:
{{state_attr(config.entity,'memory').size_mb}}
ofc, test in dev tools with
{{state_attr('sensor.rpi_monitor_piholeprimary','memory').size_mb}}
to be sure
Brilliant thanks @Mariusthvdb - Iād tried various combinations and just couldnāt get it. That works a treat thank you
I want to show the alexa timer as counter and have two questions:
a. This should be easier, but how?
{% set timer = strptime(states('sensor.echo_show_5_next_timer'),'%Y-%m-%dT%H:%M:%S%z')-now() %}
{% set sekunden = timer.seconds %}
{% set stunden = sekunden // 3600 %}
{% set sekunden = sekunden - (stunden * 3600) %}
{% set minuten = sekunden // 60 %}
{% set sekunden = sekunden - (minuten * 60 ) %}
{% if stunden >= 10 %}
{% set stundentext = stunden ~ ":" %}
{% elif stunden > 0 %}
{% set stundentext = 0 ~ stunden ~ ":" %}
{% endif %}
{{stundentext}}{{ minuten }}:{{ sekunden }}
Anyway, it is working, e.g. 22:12
b. Main question: But If I use this as state in this row, it is not updating every second. How is it possible to get it updated every second?
