Thanks for this! I’ve inserted a ‘(
’ after the “set z =
” but I still get
Error rendering template: TemplateSyntaxError: unexpected '}', expected ')'
Could it be my version of Home Assistant? It’s 0.92.1. Can’t update any further for some reason.
Okay,
in the template editor what do you get for : -
{{ strptime(states('sensor.bin') }}
{{ as_timestamp(strptime(states('sensor.bin'), '%d/%m/%y')) }}
There should not be a bracket error as : -
{% set d = (as_timestamp(strptime(states('sensor.bin'), '%d/%m/%y')) - 24*60*60) | timestamp_custom('%Y-%m-%d') %}
is what you had, and
{% set z = as_timestamp(strptime(states('sensor.bin'), '%d/%m/%y')) | timestamp_custom('%Y-%m-%d') %}
is basically the same thing but without subtracting the day ???
:puzzled:
Don’t bother using strings to do the comparisons. Use the timestamp because it makes the logic easier.
sensors:
bins_icon:
entity_id: sensor.date_time
value_template: >
{% set bin_date = strptime(states('sensor.bin'), '%d/%m/%y') %}
{% set after = as_timestamp(bin_date.replace(hour=17)) - 24*60*60 %}
{% set before = as_timestamp(bin_date.replace(hour=12)) %}
{{ after < now().timestamp() < before }}
EDIT: Just to clarify everything:
forces an update every minute on the template sensor.
Converts the timestring into a datetime object with the date day/month,2-character year at midnight. I.e. 0 oclock.
makes a timestamp at hour 17 on bin day, then subtract 24 hours (in seconds).
makes a timestamp at hour 12 on bin day.
return true if the time is between hour 17 of the night before and hour 12 of today.
just wanted to say huge thanks to muttley and petro!!!
I have to say that @petro 's solution was where I was heading (and having difficulty with).
Given that two of the entities ‘have’ to go through a timestamp phase and they are ‘by definition’ numerically sortable. It is absolutely the way to go.
Regardless, I would never have come up with the .replace(hour bit
(I’d have been fumbling with - 7x60x60 and +12x60x60)
I was trying to get the text format for the date right ie YYYY-MM-DD, HH:MM (to finagle a text sort) but why bother?
Your bin sensor coming back with d/m/y distracted me. I have learnt something here and thank you both.
Interesting - despite this evaluation TRUE in the templates dev tool, it doesn’t result in the sensor flicking to ‘on’.
sensors:
bins:
value_template: >
{% set bin_date = strptime(states('sensor.testbin_d'), '%d/%m/%y') %}
Looking at your template, I’m not surprised.
Do you have time_date set up in your config ?
See : - https://www.home-assistant.io/integrations/time_date/
Then put
entity_id : sensor.date_time above (but in line with) value_template: >
(Though sensor.time would do)
Ah ! … looking at Petro’s - just like his.
There is nothing in your template that HA feels the need to update
Eh ?
10 char min
Hey !
How does that count as 10 characters ?
Lol, it must count the characters == :man_shrugging:
