Template Switch - Value
old convo but I’m also trying to pass my harmony home control buttons into HASS and this came up so maybe a good place to deposit my solution. I accomplished this by exposing 4 switches via emulated hue. I chose non-pronounceable names since these virtual switches are only going to exist for automation purposes and I don’t want to accidentally trigger them with alexa
emulated_hue:
  host_ip: !secret hue_host_ip
  expose_by_default: false
  entities:
    switch.e8t1:
      hidden: false
    switch.e8t2:
      hidden: false
    #repeat...
input_boolean:
  e8t1:
    initial: off
  e8t2:
    initial: off
    #repeat...
switch:
    switches:
      e8t1:
        value_template: "{{ is_state('input_boolean.e8t1', 'on') }}"
        turn_on:
          service: input_boolean.turn_on
            entity_id: input_boolean.e8t1
        turn_off:
          service: input_boolean.turn_off
      #repeat...
I found out the same thing as op that template switches need to control something else, they can’t be set up as a virtual stand alone switch. when I first tried to set up the switch doing a service call on itself, my hass slowed to a crawl as my log filled up with thousands of rows of hass looping the service call, no bueno.
From where I am now, I can decide to pass through the on/off commands to other entities through automation, or I can change the target entity in the template switch and delete the input_boolean.
I’ll keep the input boolean for now and create some controls in node-red.
