123
(Taras)
May 4, 2022, 11:34pm
21
The Time Trigger will trigger at whatever time specified by the Input Datetime even if you change its value (EDIT : However, a State Trigger is also needed to detect backdated times.) There’s simply no justification for employing a Time Pattern Trigger for your intended application.
Unnecessary; the Time Trigger takes into consideration any changes made to the Input Datetime’s value. EDIT Yes, it is needed to detect backdated times.
Well it matters if the time is in the past.
Like let’s say input_datetime.onwkday1
was set to 11:00:00 and the time is currently 10:30:00. And you realized you’re cold because its winter now and mornings are colder so you want to move the time up to 10:00:00. Well now you have an issue because that time is in the past. You missed that time trigger and now it won’t trigger at 11:00:00 anymore. Everything will be fine tomorrow but what about today?
That’s where the state trigger comes in. It fires because you changed one of the helpers and re-evaluates the schedule. This causes it to recognize that the hvac should be on right now and self-correct.
(Taras)
May 5, 2022, 12:03am
23
You’re absolutely correct; I had overlooked to consider the need to backdate the scheduled time; a Time Trigger certainly won’t trigger if its time is set to the past . Your suggestion to employ a State Trigger is definitely needed to detect the change in the input_datetime’s value. Then the Time Conditions in the choose
come into play to determine which action to perform (if any).
I’ll amend my previous post.
Whag
(Whag)
May 5, 2022, 5:03pm
24
So I have changed the triggers to time at and state changes of the input times and is all working as expected without the time pattern… so thanks for this improvement.
I will now work on for loop logic to reduce the code size I will post when I get something up and running.
Two things that might be helpful:
Splitting the time triggers into ‘on’ and ‘off’ groupings so you can leverage the trigger id in your Choose action
Declaring trigger-based variables to derive the necessary time and weekday/weekend conditions.
The following only addresses actions based on the time triggers…
- platform: time
at:
- input_datetime.onwkday1
- input_datetime.onwkday2
- input_datetime.onwkday3
- input_datetime.onwkend1
- input_datetime.onwkend2
- input_datetime.onwkend3
- platform: time
at:
- input_datetime.offwkday1
- input_datetime.offwkday2
- input_datetime.offwkday3
- input_datetime.offwkend1
- input_datetime.offwkend2
- input_datetime.offwkend3
- platform: state
entity_id:
to:
- platform: state
entity_id: input_boolean.en_trv_masterbedroom
condition:
- condition: state
entity_id: input_boolean.boost_masterbedroom
state: 'off'
for:
hours: 0
minutes: 0
seconds: 10
- condition: state
state: 'on'
- variables:
dow_type: "{{ trigger.entity_id[-6:-1] }}"
dow_match: "{{ (dow_type == 'wkend' and now().isoweekday() >= 6) or (dow_type == 'wkday' and now().isoweekday() <= 5 ) }}"
time_index: "{{ trigger.entity_id[-1:] }}"
- choose:
- conditions:
- condition: trigger
- '{{ dow_match }}'
- condition: time
before: input_datetime.off{{dow_type}}{{time_index}}
sequence:
- service: climate.set_temperature
hvac_mode: auto
temperature: '{{ states(''input_number.ontemp''~time_index) }}'
entity_id: climate.trv_masterbedroom
- conditions:
- '{{ dow_match }}'
sequence:
hvac_mode: off
Whag
(Whag)
May 6, 2022, 6:36pm
26
Hey that’s nice solution, short and easy to understand.
The only issue when compiling is the time variable
- condition: time
I think the indents got thrown off when I copy/pasted back and forth from the forum, I’ve corrected it in the post above.
FWIW, I’m not sure that condition is really necessary in this configuration. I guess there might be a weird edge case that it catches…
Whag
(Whag)
May 10, 2022, 10:19pm
28
Hey thats a nice solution i have it place for one of our rooms im making a blueprint to replate it aswell it works as intended. thank you.
Whag
(Whag)
May 10, 2022, 10:23pm
29
Have to mention, 123 Traras and CentralCommand for there guidance and support thank you
Whag
(Whag)
June 10, 2022, 9:19pm
30
alias: Heating Master Bedroom Schedule
description: ''
- platform: time
at:
- input_datetime.onwkday4
- input_datetime.onwkday5
- input_datetime.onwkend4
- input_datetime.onwkend5
- platform: time
at:
- input_datetime.offwkday4
- input_datetime.offwkday5
- input_datetime.offwkend4
- input_datetime.offwkend5
- platform: state
entity_id:
- input_boolean.en_trv_masterbedroom
- input_boolean.en_trv_masterbedroomwkday1
- input_boolean.en_trv_masterbedroomwkday2
- input_boolean.en_trv_masterbedroomwkday3
- input_boolean.en_trv_masterbedroomwkday4
- input_boolean.en_trv_masterbedroomwkday5
- input_boolean.en_trv_masterbedroomwkend1
- input_boolean.en_trv_masterbedroomwkend2
- input_boolean.en_trv_masterbedroomwkend3
- input_boolean.en_trv_masterbedroomwkend4
- input_boolean.en_trv_masterbedroomwkend5
to: null
- platform: homeassistant
event: start
condition:
- condition: state
state: 'off'
for:
hours: 0
minutes: 0
seconds: 10
- condition: state
state: 'on'
- variables:
dow_type: '{{''sensor.dayofweek_type''}}'
- repeat:
until:
- condition: template
value_template: >-
{{repeat.index ==5
or
now().strftime('%H:%M:%S') < states('input_datetime.off'+
states(dow_type)~repeat.index)
and
now().strftime('%H:%M:%S') >= states('input_datetime.on'+
and
is_state('input_boolean.en_trv_masterbedroom' +
states(dow_type)~repeat.index,'on' )
sequence:
- if:
value_template: |-
{{ now().strftime('%H:%M:%S') <
states('input_datetime.off'+ states(dow_type)~repeat.index)
and now().strftime('%H:%M:%S') >=
states('input_datetime.on'+ states(dow_type)~repeat.index)
and
states(dow_type)~repeat.index,'on' )}}
then:
hvac_mode: auto
temperature: >-
{{ states("input_number.ontemp"+
states(dow_type)~repeat.index) }}
else:
hvac_mode: 'off'
temperature: >-
{{ states("input_number.offtemp"+
mode: single
Whag
(Whag)
June 10, 2022, 9:23pm
31
just an update on the above this is what i ended up doing.
