2023-02-14 14:48:58.831 ERROR (MainThread) [homeassistant.util.logging] Exception in message_received when handling msg on 'neo2/dht22': '{"humidity":26.5,"temperature":21.23}'
File "/usr/src/homeassistant/homeassistant/components/mqtt/debug_info.py", line 44, in wrapper
msg_callback(msg)
File "/usr/src/homeassistant/homeassistant/components/mqtt/sensor.py", line 307, in message_received _update_state(msg)
File "/usr/src/homeassistant/homeassistant/components/mqtt/sensor.py", line 267, in _update_state
payload = self._template(msg.payload, PayloadSentinel.DEFAULT)
File "/usr/src/homeassistant/homeassistant/components/mqtt/models.py", line 249, in async_render_with_possible_json_value
rendered_payload = self._value_template.async_render_with_possible_json_value(
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 624, in async_render_with_possible_json_value
return _render_with_context(self.template, compiled, **variables).strip()
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1984, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.10/site-packages/jinja2/environment.py", line 1301, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.10/site-packages/jinja2/environment.py", line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1889, in from_json
return json_loads(value)
orjson.JSONDecodeError: unexpected content after document: line 1 column 38 (char 37)
So it really miss something in that json string, but I don’t see something wrong.
You’re sending a character that you shouldn’t be sending at the end of your response. That’s 37 characters long, your error is indicating it’s failing at the 38th character. The encoding that you’re sending is most likely off, make sure you use ascii or utf-8 or utf-16 and strip all whitespace before dropping it in the topic.
Yes, you are right. Now made a minimal test-case from the cpp code to a python mqtt client, that failed in a similar way. Problem was this cpp code, that I made from borrowed code on std::string to char. And that extra byte should apparently NOT be there - weird.
const auto s = j.dump(); // serialize to std::string
char msgToPublish[s.length() + 1];
strcpy(msgToPublish, s.c_str());
printf("%s", msgToPublish);
pubmsg.payload = msgToPublish;
But now it works with:
char msgToPublish[s.length()];
char msgToPublish[s.length()]; // <= This is on stack
pubmsg.payload = msgToPublish; // <= You are setting the payload pointer to a stack variable that'll be cleared when leaving the function, thus payload will be a dangling pointer
The former code was better since you need to account for the zero byte in the end, but you need to initialize it. A correct code should have read:
pubmsg.payload = strdup(s.c_str()); // Make a copy on heap, including the zero byte end
// Don't forget to free the payload after publishing to avoid memory leak:
free(pubmsg.payload);
