btw, no rest allowed: https://github.com/home-assistant/core/pull/57470
only a few left, this being a prominent one in the log:
{%- set tracker_timestamp = as_timestamp(strptime(states('sensor.afvalwijzer_next_date'),'%d-%m-%Y')) %}
{% set months = ['Januari','Februari','Maart','April','Mei','Juni','Juli','Augustus','September','Oktober','November','December'] %}
{%- set wdays = ['Zondag','Maandag','Dinsdag','Woensdag','Donderdag','Vrijdag','Zaterdag'] %}
{%- set wday = tracker_timestamp|timestamp_custom('%w')|int %}
{%- set month = tracker_timestamp |timestamp_custom('%m')|int %}
{{tracker_timestamp|timestamp_custom(wdays[wday] ~ ' ' '%-d' ' ' ~ months[month-1])}}
it sees 3 warnings:
2021-10-12 00:53:36 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'strptime' got invalid input 'Geen' when rendering template '{%- set tracker_timestamp = as_timestamp(strptime(states('sensor.afvalwijzer_next_date'),'%d-%m-%Y')) %} {% set months = ['Januari','Februari','Maart','April','Mei','Juni','Juli','Augustus','September','Oktober','November','December'] %} {%- set wdays = ['Zondag','Maandag','Dinsdag','Woensdag','Donderdag','Vrijdag','Zaterdag'] %} {%- set wday = tracker_timestamp|timestamp_custom('%w')|int %} {%- set month = tracker_timestamp |timestamp_custom('%m')|int %} {{tracker_timestamp|timestamp_custom(wdays[wday] ~ ' ' '%-d' ' ' ~ months[month-1])}}' but no default was specified. Currently 'strptime' will return 'Geen', however this template will fail to render in Home Assistant core 2021.12
2021-10-12 00:53:36 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'as_timestamp' got invalid input 'Geen' when rendering template '{%- set tracker_timestamp = as_timestamp(strptime(states('sensor.afvalwijzer_next_date'),'%d-%m-%Y')) %} {% set months = ['Januari','Februari','Maart','April','Mei','Juni','Juli','Augustus','September','Oktober','November','December'] %} {%- set wdays = ['Zondag','Maandag','Dinsdag','Woensdag','Donderdag','Vrijdag','Zaterdag'] %} {%- set wday = tracker_timestamp|timestamp_custom('%w')|int %} {%- set month = tracker_timestamp |timestamp_custom('%m')|int %} {{tracker_timestamp|timestamp_custom(wdays[wday] ~ ' ' '%-d' ' ' ~ months[month-1])}}' but no default was specified. Currently 'as_timestamp' will return 'None', however this template will fail to render in Home Assistant core 2021.12
2021-10-12 00:53:36 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'timestamp_custom' got invalid input 'None' when rendering template '{%- set tracker_timestamp = as_timestamp(strptime(states('sensor.afvalwijzer_next_date'),'%d-%m-%Y')) %} {% set months = ['Januari','Februari','Maart','April','Mei','Juni','Juli','Augustus','September','Oktober','November','December'] %} {%- set wdays = ['Zondag','Maandag','Dinsdag','Woensdag','Donderdag','Vrijdag','Zaterdag'] %} {%- set wday = tracker_timestamp|timestamp_custom('%w')|int %} {%- set month = tracker_timestamp |timestamp_custom('%m')|int %} {{tracker_timestamp|timestamp_custom(wdays[wday] ~ ' ' '%-d' ' ' ~ months[month-1])}}' but no default was specified. Currently 'timestamp_custom' will return 'None', however this template will fail to render in Home Assistant core 2021.12
please help me out where to ad some defaults? Though this mentions the input being invalid, and I am not sure how to handle that. The input is ok however, and currently as intended…
the only other warningI get is on the DST sensor:
2021-10-12 00:53:37 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'timestamp_local' got invalid input '167 days, 0:00:00' when rendering template '{%- set ns = namespace(previous=2,spring=none,fall=none) %} {%- set today = strptime(states('sensor.date'),'%Y-%m-%d').astimezone().replace(hour=ns.previous) %} {%- for i in range(365) %} {%- set day = (today + timedelta(days=i)).astimezone() %} {%- if ns.previous - day.hour == -1 %} {%- set ns.spring = today + timedelta(days=i)|timestamp_local %} {%- elif ns.previous - day.hour == 1 %} {%- set ns.fall = today + timedelta(days=i)|timestamp_local %} {%- endif %} {%- set ns.previous = day.hour %} {%- endfor %} {{([ns.spring,ns.fall]|min).isoformat()}}' but no default was specified. Currently 'timestamp_local' will return '167 days, 0:00:00', however this template will fail to render in Home Assistant core 2021.12
but that was before I deleted |timestamp_local
. Must re-read this thread again to understand why I can now take that out, or why that caused the error…
