Nothing wrong with Fortran
yup.
Thanks once again for all your help Petro - No more errors!
The only thing I changed was
{{ (humidities | sum / humidities | count) | round(2)}}
Just to tidy up the output.
Correct.
@bschatzow
Never used python until Home Assistant. I know just enough now to get by. Lots of online python resources (Google is your friend).
Does it make sense to start with Jinja tutorials?
Probably since most of what is shown in this thread is Jinja2 (with a smattering of python). However, good luck finding Jinja2 tutorials targeted for Home Assistantâs implementation of Jinja2.
The official Jinja2 documentation is thorough but dry and not everything it describes is implemented in Home Assistant. I found the most useful section to be the lists of Builtin Filters and Builtin Tests but not all are available in Home Assistant and there are custom filters not mentioned in Jinja2âs documentation.
I donât think they exist. You might get something looking up ansible, not entirely sure what the link is between the 2 but it seems to be more widely used.
duh⌠ofc. thanks (being quite for a moment to contemplate my blunder)
.19âŚ20âŚ
do we already have consensus on that that would be âcorrectyâ ?
I mean we can set |float(0)
but that would only mean the template always succeeds, not perse the value is useful or even correct . If the value of an mqtt sensor would be unavailable and we float it to default, it still is evaluated as 0, with rather undesired consequencesâŚ
need to default to float(none) after all then?
even worse: ive got a group with power sensors, some of which are turned off , as in dont have a power reading at all, being unavailable. the template sensor returns
Template warning: 'float' got invalid input 'unavailable' when rendering template '{{(expand('group.lights_inside_total_device_power')
on those:
{{states('sensor.lights_inside_total_device_power')|float +
states('sensor.lights_outside_total_device_power')|float}}
based on
|map(attribute='state')|map('float')|sum)|round(2)}}
where to set a (which) default�
testing this for a reload
|map('float',0)
which should be fine for the individual power sensors, but not for the energy sensors (they are total_increasingâŚ)
also, the all lights power sensor (derived from the expand group template) shouldnât default to 0 either, because it never can/will/should be 0âŚ
I would hope we do. Like any computer language there are rules, definitions, etc. The problem with most of us (myself included) I really did not understand what the code was doing when I copied different examples and modified them to my system. I would think if you follow the rules and you understand what each statement is doing it âshouldâ work. If it doesnât I believe with the experts here someone will be able to explain why.
I am still trying to understand what each line in my âcopied codeâ does. Most of my errors have to do with command line sensors used to show updates on core, system, hacs, etc. Other errors have to do with markdown cards that are using templates. Again, I justed edited them and changed the sensors to my sensors. This worked well for me until this release.
So this templateâŚ
{{ max|round(0,default='none')}}°/{{ min|round(0,default='none')}}°/{{states('sensor.kariong_rain_chance_0')|round(0,default='none')}}%
I previously used round(0) to round to 0 decimal places (I thought) Now I added the default=ânoneâ as I donât want it using 0 as the default. It also wouldnât work without the default=
part.
In the docs for round it seems that round(x,y,z)
is the syntax? Where x is the rounding, y could be floor or ceiling and z is the default but I am only seeing the default in the above examples. Why do I have to use default=
If you donât provide the second argument, you need to provide the word default so that the code knows itâs the value for default.
thanks that simplifies it quite a bit.
btw, no rest allowed: https://github.com/home-assistant/core/pull/57470
only a few left, this being a prominent one in the log:
{%- set tracker_timestamp = as_timestamp(strptime(states('sensor.afvalwijzer_next_date'),'%d-%m-%Y')) %}
{% set months = ['Januari','Februari','Maart','April','Mei','Juni','Juli','Augustus','September','Oktober','November','December'] %}
{%- set wdays = ['Zondag','Maandag','Dinsdag','Woensdag','Donderdag','Vrijdag','Zaterdag'] %}
{%- set wday = tracker_timestamp|timestamp_custom('%w')|int %}
{%- set month = tracker_timestamp |timestamp_custom('%m')|int %}
{{tracker_timestamp|timestamp_custom(wdays[wday] ~ ' ' '%-d' ' ' ~ months[month-1])}}
it sees 3 warnings:
2021-10-12 00:53:36 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'strptime' got invalid input 'Geen' when rendering template '{%- set tracker_timestamp = as_timestamp(strptime(states('sensor.afvalwijzer_next_date'),'%d-%m-%Y')) %} {% set months = ['Januari','Februari','Maart','April','Mei','Juni','Juli','Augustus','September','Oktober','November','December'] %} {%- set wdays = ['Zondag','Maandag','Dinsdag','Woensdag','Donderdag','Vrijdag','Zaterdag'] %} {%- set wday = tracker_timestamp|timestamp_custom('%w')|int %} {%- set month = tracker_timestamp |timestamp_custom('%m')|int %} {{tracker_timestamp|timestamp_custom(wdays[wday] ~ ' ' '%-d' ' ' ~ months[month-1])}}' but no default was specified. Currently 'strptime' will return 'Geen', however this template will fail to render in Home Assistant core 2021.12
2021-10-12 00:53:36 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'as_timestamp' got invalid input 'Geen' when rendering template '{%- set tracker_timestamp = as_timestamp(strptime(states('sensor.afvalwijzer_next_date'),'%d-%m-%Y')) %} {% set months = ['Januari','Februari','Maart','April','Mei','Juni','Juli','Augustus','September','Oktober','November','December'] %} {%- set wdays = ['Zondag','Maandag','Dinsdag','Woensdag','Donderdag','Vrijdag','Zaterdag'] %} {%- set wday = tracker_timestamp|timestamp_custom('%w')|int %} {%- set month = tracker_timestamp |timestamp_custom('%m')|int %} {{tracker_timestamp|timestamp_custom(wdays[wday] ~ ' ' '%-d' ' ' ~ months[month-1])}}' but no default was specified. Currently 'as_timestamp' will return 'None', however this template will fail to render in Home Assistant core 2021.12
2021-10-12 00:53:36 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'timestamp_custom' got invalid input 'None' when rendering template '{%- set tracker_timestamp = as_timestamp(strptime(states('sensor.afvalwijzer_next_date'),'%d-%m-%Y')) %} {% set months = ['Januari','Februari','Maart','April','Mei','Juni','Juli','Augustus','September','Oktober','November','December'] %} {%- set wdays = ['Zondag','Maandag','Dinsdag','Woensdag','Donderdag','Vrijdag','Zaterdag'] %} {%- set wday = tracker_timestamp|timestamp_custom('%w')|int %} {%- set month = tracker_timestamp |timestamp_custom('%m')|int %} {{tracker_timestamp|timestamp_custom(wdays[wday] ~ ' ' '%-d' ' ' ~ months[month-1])}}' but no default was specified. Currently 'timestamp_custom' will return 'None', however this template will fail to render in Home Assistant core 2021.12
please help me out where to ad some defaults? Though this mentions the input being invalid, and I am not sure how to handle that. The input is ok however, and currently as intendedâŚ
the only other warningI get is on the DST sensor:
2021-10-12 00:53:37 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'timestamp_local' got invalid input '167 days, 0:00:00' when rendering template '{%- set ns = namespace(previous=2,spring=none,fall=none) %} {%- set today = strptime(states('sensor.date'),'%Y-%m-%d').astimezone().replace(hour=ns.previous) %} {%- for i in range(365) %} {%- set day = (today + timedelta(days=i)).astimezone() %} {%- if ns.previous - day.hour == -1 %} {%- set ns.spring = today + timedelta(days=i)|timestamp_local %} {%- elif ns.previous - day.hour == 1 %} {%- set ns.fall = today + timedelta(days=i)|timestamp_local %} {%- endif %} {%- set ns.previous = day.hour %} {%- endfor %} {{([ns.spring,ns.fall]|min).isoformat()}}' but no default was specified. Currently 'timestamp_local' will return '167 days, 0:00:00', however this template will fail to render in Home Assistant core 2021.12
but that was before I deleted |timestamp_local
. Must re-read this thread again to understand why I can now take that out, or why that caused the errorâŚ
I though I understood what to do but I have a simple sensor that is giving a warning.
platform: template
sensors:
total_distance_mtr_miles:
friendly_name: "miles_walked"
unit_of_measurement: 'miles'
#added round(2,default=0) 10/8/2021
value_template: "{{ states('sensor.total_distance_mtr') | multiply (1/1609.3444) | float(2) | round(2,default=0)}}"
- Template warning: âmultiplyâ got invalid input âunavailableâ when rendering template â{{ states(âsensor.total_distance_mtrâ) | multiply (1/1609.3444) | float(2) | round(2,default=0)}}â but no default was specified. Currently âmultiplyâ will return âunavailableâ, however this template will fail to render in Home Assistant core 2021.12
Tried float (defaultt=0) and it didnât help.
Itâs saying that the value multiply
received was unavailable
. That means the result of states('sensor.total_distance_mtr')
was unavailable
Even if it wasnât unavailable
, the sensorâs state
value is a string and you canât do arithmetic with strings (you have to first convert them to numbers using float
or int
I thought I did with the float? It has worked for several years as is. Is the order wrong in the statement? I tried float | multiply (changed order) and no difference. It is just converting the garmin meters to miles. Why would the Meters be a string?
The float is applied to what comes before it. Thatâs how filters work.
what_filter_is_apply_to | filter
Youâre applying the filter to
it should be
states('sensor.total_distance_mtr') | float(2) | multiply (1/1609.3444) | round(2,default=0)
also, I think multiply needs a default too.
Also multiply converts strings to floats for you.
soâŚ
states('sensor.total_distance_mtr') | multiply (1/1609.3444, 0) | round(2,default=0)
On multiple you donât need , default=0?
No, multiply only takes 2 arguments. So you donât need to call out the names because you arenât omitting an argument.
See:
the only reason you need to use the word default is when the argument you are trying to set is not the next argument thatâs required.
I.e. my_method(arg1, arg2=True, arg3=47)
requires 3 arguments named arg1
, arg2
, and arg3
. arg1
is required and arg2
and arg3
are optional, because they have a default value for them. When you omit arg2
and arg3
, they auto populate my_method
with True
and 47
. Meaning if you call my_method
with my_method(7)
, arg1
will have 7
, arg2
will have True
, and arg3
will have 47
. Well, what happens when you want to supply my_method
with arg3
as 50
instead of 47
? Well you have 2 options. Populate all 3 arguments; my_method(7, True, 50)
or supply the single argument you want to populate my_method(7, arg3=50)
This is why you see default used and not used all over the place. FYI you can also supply all 3 and it still works; my_method(7, arg2=True, arg3=50)
