That’s not the correct way to do it. The first state_changed event for all entities will have trigger.event.data.old_state equal to None. In that case trigger.event.data.old_state.state will cause an error (because None does not have an attribute named state.) The correct way is:
Sorry about the inconsistency, its for a binary_sensor.
I don’t understand the code and how to I test the state for an value?
What I am trying to do, is to have one binary sensor changing to “ON” if one of many sensors with battery level goes under 15%.
This way if one of my sensors with battery level goes under 15%. I can have one alert firing when the binary sensor changes to “on”.
value_template: >-
{% set domain, object_id = trigger.event.data.entity_id.split('.', 1) %}
{{ domain == 'sensor' and 'battery' in object_id }}
??{{ object_id.*battery*') < 15 }}??
So you’re saying you have some entities in the sensor domain that each have an attribute whose name contains the word “battery”, and you want to create a binary_sensor whose state should be 'on' if any of those attributes have a value less than 15? Is that it?
Wait, this gets more complicated each time you clarify. I’m still unclear exactly what you’re looking for.
So some sensor entities have an entity ID that is like "sensor.*battery_level*" (i.e., they have "battery_level" in their object IDs), and their states indicate battery levels. And some other sensor entities have an attribute named "battery_level", or have "battery_level" in the name of one of their attributes, and they also indicate battery levels. And you want a new binary_sensor that is on if any of those states or attributes indicate a level below 15. Is that it?
value_template: >
{% set ns = namespace(count=0) %}
{% for state in states.sensor if 'battery_level' in state.entity_id and
state.state|float(100) < 15 %}
{% set ns.count = ns.count + 1 %}
{% endfor %}
{{ ns.count > 0 }}
I specified a default value of 100 for the float filter so that values that cannot be interpreted as a number (e.g., 'unavailable' or 'unknown') don’t cause the template to result in true. But, if you do want those to turn the binary sensor on, then just change “float(100)” to “float”.
No, it’s not strange. It’s expected. You’re probably getting a warning about it not being able to detect any entity IDs. You need to make the sensor update, since it won’t on its own. Either add something like
entity_id: sensor.time
Or set up an automation to update it periodically. That’s the problem with using a template like this for a sensor.
Could you please double check if this actually does anything in your setup (like removing it and checking if the behaviour has changed)?
Im trying to do something similar to your automation, but found out that domain property of event_data is not documented and doesnt work for me.
