Thanks for taking the time to look will look at it in the dev tools now
Hi that has got that section of code working so thanks.
However the last section is now the issue
states:
'true':
type: custom:mushroom-template-card
primary: Expected time left
secondary: >-
{{ (states('sensor.washing_machine_expected_time_left') |
float| timestamp_custom(' %H:%M:%S ', False)) }}
icon: mdi:clock
entity: sensor.washing_machine_expected_time_left
icon_color: blue
fill_container: true
layout: vertical
With the same error of but no default was specified which I don’t understand now
are you sure it’s the same error, verbatim?
ValueError: Template error: float got invalid input 'unavailable' when rendering template 'square: false columns: 2 type: grid cards: - type: custom:state-switch entity: template template: >- {% if as_timestamp(states('input_datetime.washing_stopped'), default=0) < as_timestamp(states('input_datetime.washing_started'), default=0) %} true {% else %} false {% endif %} states: 'true': type: custom:mushroom-template-card secondary: >- {{ as_timestamp(states('input_datetime.washing_expected_time_to_stop'), default=0) | timestamp_custom(' %H:%M:%S ', True) }} icon: mdi:clock icon_color: blue layout: vertical fill_container: true primary: Expected End Time - type: custom:state-switch entity: template template: >- {% if (as_timestamp(states('input_datetime.washing_stopped'), default=0) < as_timestamp(states('input_datetime.washing_started'), default=0)) and (states('sensor.washing_machine_expected_time_left') | float(0) > 0 ) %} true {% else %} false {% endif %} states: 'true': type: custom:mushroom-template-card primary: Expected time left secondary: >- {{ (states('sensor.washing_machine_expected_time_left') | float| timestamp_custom(' %H:%M:%S ', False)) }} icon: mdi:clock entity: sensor.washing_machine_expected_time_left icon_color: blue fill_container: true layout: vertical' but no default was specified
this is the error code it comes up with
you said it was the same error, but it’s clearly not, right?
in the dev tools template what do you get when you do this:
{{ states('sensor.washing_machine_expected_time_left') }}
NO errors and a output like this
square: false
columns: 2
type: grid
cards:
entity: template
template: >-
false
states:
'true':
secondary: >-
01:00:00
icon: mdi:clock
icon_color: blue
layout: vertical
entity: template
template: >-
false
states:
'true':
secondary: >-
unavailable
icon: mdi:clock
icon_color: blue
layout: vertical
updating the thread. since we took some of this into chat.
the sensor is returning ‘unavailable’ so obviously that’s not going to work… so there’s a problem before it gets to this code.
