Yes. I’ve updated but still showing unavailable. I have done no fresh authentication just the updates. Thanks.
Mine is all good and working now. Integration showed up and got authorized.
I have exactly the same problem.(v2021.2.3)
I get exactly the same error too on version 2021.2.3. Deleted the integration, restarted HA and then tried to re-add and I get this error.
Logger: aiohttp.server
Source: components/tesla/config_flow.py:157
First occurred: 21:14:03 (1 occurrences)
Last logged: 21:14:03
Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 118, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 169, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 60, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 106, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 155, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 213, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/tesla/config_flow.py", line 57, in async_step_user
info = await validate_input(self.hass, user_input)
File "/usr/src/homeassistant/homeassistant/components/tesla/config_flow.py", line 157, in validate_input
(config[CONF_TOKEN], config[CONF_ACCESS_TOKEN]) = await controller.connect(
File "/usr/local/lib/python3.8/site-packages/teslajsonpy/controller.py", line 268, in connect
cars = await self.get_vehicles()
File "/usr/local/lib/python3.8/site-packages/backoff/_async.py", line 133, in retry
ret = await target(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/teslajsonpy/controller.py", line 357, in get_vehicles
return (await self.__connection.get("vehicles"))["response"]
File "/usr/local/lib/python3.8/site-packages/teslajsonpy/connection.py", line 78, in get
return await self.post(command, "get", None)
File "/usr/local/lib/python3.8/site-packages/teslajsonpy/connection.py", line 96, in post
self.code = await self.get_authorization_code(
File "/usr/local/lib/python3.8/site-packages/teslajsonpy/connection.py", line 372, in get_authorization_code
code_url = URL(resp.history[-1].url)
IndexError: tuple index out of range
Exactly the same setup and steps and also got an unknown error and this error log:
First occurred: 20 February 2021, 22:54:11 (6 occurrences)
Last logged: 6:50:42Error handling request
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py”, line 422, in _handle_request
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py”, line 499, in _handle
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py”, line 118, in impl
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 56, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 18, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 72, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 127, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 129, in handle
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 169, in post
File “/usr/src/homeassistant/homeassistant/components/http/data_validator.py”, line 60, in wrapper
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 106, in post
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 155, in async_configure
result = await self._async_handle_step(flow, cur_step[“step_id”], user_input)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 213, in _async_handle_step
File “/usr/src/homeassistant/homeassistant/components/tesla/config_flow.py”, line 57, in async_step_user
File “/usr/src/homeassistant/homeassistant/components/tesla/config_flow.py”, line 157, in validate_input
File “/usr/local/lib/python3.8/site-packages/teslajsonpy/controller.py”, line 268, in connect
File “/usr/local/lib/python3.8/site-packages/backoff/_async.py”, line 133, in retry
File “/usr/local/lib/python3.8/site-packages/teslajsonpy/controller.py”, line 357, in get_vehicles
return (await self.__connection.get(“vehicles”))[“response”]
File “/usr/local/lib/python3.8/site-packages/teslajsonpy/connection.py”, line 78, in get
return await self.post(command, “get”, None)
File “/usr/local/lib/python3.8/site-packages/teslajsonpy/connection.py”, line 96, in post
File “/usr/local/lib/python3.8/site-packages/teslajsonpy/connection.py”, line 372, in get_authorization_code
IndexError: tuple index out of range’
Not sure this is helpful, but mine is working again. I updated to 2020.2.3 a few days ago. That didn’t immediately resolve it, but today after an unrelated update to HASS OS 5.12 everything came back online. For those just coming across this thread, maybe try another restart.
Same here! Now I just need to get the powerwall automations I had working again…
anyone else seeing this starting today? Unexpected error fetching tesla data: tuple index out of range
Yes, I also get
I’m on 2021.2.3
seems to have sorted itself out, odd.
Hi Is this generally fixed as mine is still showing unavailable. Is there something I can do to reconnect?
I deleted and readded the integration with a restart in between. No issues.
THanks - Did the trick
Deleted Tesla, restarted, now Tesla integration refuses login credentials.
I just tried to set up the Tesla integration for the first time, but after entering my e-mail address and password I get an error. The log shows:
Source: components/tesla/config_flow.py:159
First occurred: 18:55:44 (2 occurrences)
Last logged: 18:56:11
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 74, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 135, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 131, in handle
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 155, in post
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 107, in post
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 156, in async_configure
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 214, in _async_handle_step
result: dict = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/tesla/config_flow.py", line 159, in validate_input
So that looks like the error mentioned before. I have set-ups two-factor authentication on my Tesla account. Perhaps this integration can’t handle that?
Tesla wasn’t working for me either.
Removed integration, tried adding, restart, tried adding, but no success.
I don’t have MFA enabled. But I would understand that the integration can’t handle MFA.
At the bottom of the stacktrace: tuple index out of range
Edit: Known issue at Unable to add Tesla integration · Issue #46397 · home-assistant/core · GitHub
Same error here.
I even added a dedicated account (because the integration sadly doesn‘t support 2fa) - and still „unknown error“.
Exactly the same errors in logs here
I have same error, so I subscribe.
Same here
