The -d flag means the container runs in the background. If you type docker logs c8b3e2632f7664d67346f9a5aa4bd2d86a0471bcf9a4fcad5013294f55c3eed6 you should see the log output.
Thanks for your help. Now my Docker is running with texecom image and Log is showing everything running smoothly
2020-09-01 07:16:40 - DEBUG: Publishing to texecom-1010987/power: {“battery_charging_current”:18,“battery_voltage”:13.56,“panel_current”:585,“panel_voltage”:13.7}
In Hass.io I have installed Mosquitto Broker and have setup the integration also but still there are no devices or entities showing in integration. Below is the Mosquitto Broker Log:
[17:52:58] INFO: Setup mosquitto configuration
[17:52:58] INFO: Found local users inside config
[17:53:00] INFO: Initialize Hass.io Add-on services
[17:53:00] INFO: Initialize Home Assistant discovery
[17:53:00] INFO: Start Mosquitto daemon
1598876581: mosquitto version 1.6.3 starting
1598876581: Config loaded from /etc/mosquitto.conf.
1598876581: Loading plugin: /usr/share/mosquitto/auth-plug.so
1598876581: |-- *** auth-plug: startup
1598876581: ├── Username/password checking enabled.
1598876581: ├── TLS-PSK checking enabled.
1598876581: └── Extended authentication not enabled.
1598876581: Opening ipv4 listen socket on port 1883.
1598876581: Opening ipv6 listen socket on port 1883.
1598876581: Opening websockets listen socket on port 1884.
1598876581: Opening ipv4 listen socket on port 8883.
1598876581: Opening ipv6 listen socket on port 8883.
1598876581: Opening websockets listen socket on port 8884.
1598876581: Warning: Mosquitto should not be run as root/administrator.
1598876596: New connection from 172.30.32.1 on port 1883.
[INFO] found homeassistant on local database
1598876599: New client connected from 172.30.32.1 as auto-15E28A24-B5D9-3ADD-849A-B5F0EA82C56A (p2, c1, k60, u’homeassistant’).
1598876684: Socket error on client auto-15E28A24-B5D9-3ADD-849A-B5F0EA82C56A, disconnecting.
1598878382: Saving in-memory database to /data/mosquitto.db.
1598878962: New connection from xxx.xxx.2.198 on port 1883.
[INFO] found my_user on local database
1598878972: New client connected from xxx.xxx.2.198 as texecom2mqtt (p2, c1, k30, u’my_user’).
1598879008: New connection from 172.30.32.1 on port 1883.
1598879012: New client connected from 172.30.32.1 as auto-8D3A7AA9-2804-A880-349A-E8ECE6875BCE (p2, c1, k60, u’homeassistant’).
1598879012: Client auto-8D3A7AA9-2804-A880-349A-E8ECE6875BCE disconnected.
1598879012: New connection from 172.30.32.1 on port 1883.
1598879012: New client connected from 172.30.32.1 as auto-A2F71370-2D95-FCBA-3390-D996DA093D6D (p2, c1, k60, u’homeassistant’).
1598879050: Socket error on client auto-A2F71370-2D95-FCBA-3390-D996DA093D6D, disconnecting.
1598879050: New connection from 172.30.32.1 on port 1883.
1598879050: New client connected from 172.30.32.1 as auto-09C144E1-92F6-EF75-64F1-AE3753E78641 (p2, c1, k60, u’homeassistant’).
1598880183: Saving in-memory database to /data/mosquitto.db.
1598881530: Client texecom2mqtt has exceeded timeout, disconnecting.
1598881984: Saving in-memory database to /data/mosquitto.db.
1598883785: Saving in-memory database to /data/mosquitto.db.
1598885586: Saving in-memory database to /data/mosquitto.db.
1598886242: Client auto-09C144E1-92F6-EF75-64F1-AE3753E78641 has exceeded timeout, disconnecting.
1598886245: New connection from 172.30.32.1 on port 1883.
1598886249: New client connected from 172.30.32.1 as auto-C47AE5E3-DF16-0476-DE59-581FF84A7F5F (p2, c1, k60, u’homeassistant’).
1598887387: Saving in-memory database to /data/mosquitto.db.
1598888716: New connection from xxx.xxx.2.198 on port 1883.
1598888719: New client connected from xxx.xxx.2.198 as texecom2mqtt (p2, c1, k30, u’my_user’).
1598888719: Socket error on client texecom2mqtt, disconnecting.
1598889188: Saving in-memory database to /data/mosquitto.db.
1598941420: Saving in-memory database to /data/mosquitto.db.
1598941630: New connection from xxx.xxx.2.198 on port 1883.
1598941633: New client connected from xxx.xxx.2.198 as texecom2mqtt (p2, c1, k30, u’my_user’).
1598943221: Saving in-memory database to /data/mosquitto.db.
My Raspberry pi is on xxx.xxx.2.31 and my Laptop is on xxx.xxx.2.198
This looks interesting @dchesterton - i have a risco panel at the moment which has HA support but runs via the cloud so PIR responses can be a little slow and when used for light trigger it obviously has issues.
I’m moving house and looking for a new panel - if i went texecom premier elite does this integration get local updates from the panel or are they via cloud and may suffer the same lag ?
Thanks a lot
Question, if I use this docker component to add HA integration can I still have my alarm monitored by an external company?
Well, I use this integration and have an external monitoring company. You need a spare ComIp or SmartCom if you still want to use the app in my experience thought.
This integration is probably the best bit of my (quite) large HA setup
Andrew
Hi AGW,
Thanks for this. I literally have just configured the panel (texecom premier elite) and I opted for the 4g+WIFI smartcom. I thought, if your gonna do it , do it proper.
I assume if I want to use the integration, and still have access to texecom cloud (wifi+4g) will will need the comIp, right?
Angelo
@dchesterton I have created the docker-compose.yml file and the config.yml file, I’m unable to find how to mount this file as a volume in Docker on windows. Any guidance please? Thanks.
@dchesterton I feel I have made progress but cannot seem to get this config file bound. Anyone have any help please with the command line? Thanks.
PS C:\Users\user> docker run -d -v $PWD/SystemWidgets/config.yml:/app/config.yml --name texecom2mqtt dchesterton/texecom2mqtt:latest
a70df8405d98acbb674cb48eb74ca90af22799309478d86464fb57ec3ab3f5c9
PS C:\Users\user> docker logs a70df8405d98acbb674cb48eb74ca90af22799309478d86464fb57ec3ab3f5c9 /snapshot/app/dist/config.js:51
throw new Error(Error loading config file: ${e});
Error: Error loading config file: Error: EISDIR: illegal operation on a directory, read
at loadYamlConfig (/snapshot/app/dist/config.js:51:15)
at loadConfig (/snapshot/app/dist/config.js:62:24)
at /snapshot/app/dist/index.js:11:44
at Object. (/snapshot/app/dist/index.js:81:3)
at Module._compile (pkg/prelude/bootstrap.js:1794:22)
at Object.Module._extensions…js (node:internal/modules/cjs/loader:1153:10)
at Module.load (node:internal/modules/cjs/loader:981:32)
at Function.Module._load (node:internal/modules/cjs/loader:822:12)
at Function.runMain (pkg/prelude/bootstrap.js:1847:12)
at node:internal/main/run_main_module:17:47
