I ran into a problem using the method with media_player.volume_set.
When trying to set the volume to for example 0.5, when the volume was already 0.5, the issue with the sound beeing cut at the beginning was still present. And setting different sound levels, 0.51 and 0.52 for different TTS announcements feels like a bad idea.
I also tried to mute and unmute the sound before playing the TTS message, but the problem was present there too.
Delay for 0.1 seconds (without this delay, the problem persist)
Then play the TTS announcement.
In combination with the automation from @lolouk44 the Chromecast Audio doesn’t go to sleep and the TTS are played without cut-outs (as of now). I will continue with my testing and let you now of any further failures.
Today I have found yet another way to solve the issue at hand. And it works without both the automation playing a 1 seconds silence every two minutes (which by the way stops the music when playing from a music app on the iPhone) and without changing the volume before every TTS announcment.
For some reason I cannot explain it works perfect (at least in my setup)
if you look at my automation it’ll check that the GH is not already playing before it plays the 1 sec audio
(actually I check that each individual GH and the group with both my GH devices isn’t in playing state )
Your method with work too though you’d have an ever slight delay before you hear the announcement, and most likely you’ll also hear the connection chime which I hate…
Yes, I noticed that But that only work if I stream music from Home Assistant to the Chromecast Audio. When I stream music from Spotify and apps alike to the Chromecast, Home Assistant is unaware of the status of the Chromecast Audio. It is seen as off.
That was the weird thing. When using the wait_template and the delay I don’t hear the “connection chime”, it just starts playing the TTS announcement, perfectly complete. Even if the Chromecast is in the idle or off state.
Maybe you could give it a shot and see how your device behave? There might be some difference in how the Google Home and the Chromecast Audio operate. I would be really interested anyway because I intend to buy a Google Home Mini soon
Interesting. Google Home acts as a ChromeCast audio so from from HA’s point of view it makes not difference. I actually use ChromeCasts to play music and my GH’s for announcements (and regular interactions)
I’ll see if I get some time to try your method…
Also I personally find that audio/mp4 is more reliable than other formats. Can you can try for both the doorbell play and the keep alive?
Also you mentioned TTS, but it looks like you’re playing some MP3 file. Where is the TTS?
What happens when you manually play the mp3 on the media_player via the Services tab?
Not that it should, but wondering if setting the volume makes the CC “busy”.
Have you tried to add a delay of like 1 sec between volume set and play? I don’t have that issue personally, but worth a try
For me it’s the same, not entirely sure why. I ended up loading the sound files on my webserver (apache) and linking to it using the server’s IP address rather than going online for it.
No matter what I do the chromecast audio always misses the beginning portion of the sound, using TTS or playing a file, if called from an automation or script, even when the media player is on and idle.
I’ve tired all the suggestions listed in the thread above, I’ve improved my wifi (using unifi APs now) I’ve tried caching the audio, not caching, adding up to 5 seconds of silence to the beginning of media files (not a viable solution for a doorbell anyway), and loads more.
Fortunately I have an iPad that I can play sounds attached to messages without problem so I’m going with that for now.
This is great. Thanks so much! Was having issues where it would give the notification noise on the Minis but then maybe 1 of them would actually play the notification that I had setup. Now it should play them everywhere and always when they trigger!
Finally worked out what was wrong with my set up. The powered speaker I plugged my chromecast audio into takes forever to recognise something is playing and unmute.
Nothing wrong with TTS or media player. It was the speaker!
