Thanks Petro, this is great. Which Jinja reference would you recommend for learning and/or referencing such functions i.e. today_at()
The two links in the developer tools are always a good starting point.
I checked the ones at the HA Templates page⦠will re-check again though.
Much appreciate your advice. Thanks
Rami
I think this is what youāre looking for:
{% set last_changed = states.binary_sensor.main_door.last_changed %}
{% if last_changed < today_at() - timedelta(days=6) %}
More than a week ago
{% elif last_changed < today_at() - timedelta(days=1) %}
{{ last_changed.strftime('%A at %H:%M') }}
{% elif last_changed < today_at() %}
{{ last_changed.strftime('Yesterday at %H:%M') }}
{% else %}
{{ last_changed.strftime('Today at %H:%M') }} ({{ relative_time(last_changed) }} ago)
{% endif %}
Hi Petro,
May I trouble you with one last thing⦠Iāve trying to get it to work with no luck after several trial, I guess I need to do some intensive reading about States and Attributes.
What if instead of last changed attribute (which changes after each restart, I want to use an input_datetime helper to make it persistant over re-start⦠how can I insert this in your code.
It keeps giving me error either no attribute or canāt use < between strings and datetime.
Sorry for the inconvenience
States are always strings, so you will need to convert the state of the Input datetime helper to a offset-aware datetime object by replacing the first line of the template:
{% set last_changed = states('input_datetime.XXXX') | as_datetime | as_local %}
Thank you big time. I can now see what I did wrong⦠I had the as_local filter before the | as_datetime⦠makes perfect sense now and works flawlessly.
Much appreciated
RS
Iām trying to format elapsed time into something like ##d ##h ##m or ##:##:##
Hereās what Iāve got so far:
{{ (as_timestamp(now()) - as_timestamp(states('sensor.uptime'))) | timestamp_custom('%dd %hh %mm') }}
Which gives me 31d Dech 12m off an epoch of ~9000 which should be more like 0d 2h 30m. Whatās the proper syntax to depict elapsed time from 0 instead of the start of the epoch?
This will be formatted ddd hh:mm:ss
{{ now() - states('sensor.uptime') | as_datetime | as_local }}
If you want a custom format, you have to do the math.
Hereās the math laid outā¦
With all that Python/Jinja2 is capable ofā¦is that really the most compact way to convert/format seconds into another timeframe?
Yes, there is no way to format a timedelta thatās naturally built into python or jinja.
Just so you know, most languages donāt have this. I was surprised when I found out that C# does have it, but the implementation is terrible in comparison to the strftime equivalent.
Wow! Thatās seems like something that shouldāve been handled already. OK, thank you.
I use this on my āRouterā uptime sensor , sure i didnāt bother about showing D/H/M, as i have a āpersonal perspectiveā of the word āUserFriendlyā
⦠itās my system, only i need to understand ![]()
- type: custom:template-entity-row
active: true
state: >
{% set s = states('sensor.rt_ax68u_d680_uptime')| int(3) %}{{
'%02d:%02d:%02d' % ((s/86400)|int(3),((s%86400) /
3600)|int(3),(s%3600) / 60) }}
Thanks. It doesnāt work for me. I get 00:00:00 using the whole thing. What type and format does your sensor output and what does the output of that template look like?
{% set s = states('sensor.uptime')| int(3) %}
{{'%02d:%02d:%02d' % ((s/86400)|int(3),((s%86400) / 3600)|int(3),(s%3600) / 60) }}
{{ s }}
{{ states('sensor.uptime') }}
gives me
if htatās what you want, just use what I linked, no point in re inventing the wheel
{%- set up_time = as_timestamp(now())-as_timestamp(states('sensor.uptime')) %}
{%- macro phrase(name, divisor, mod=None) %}
{%- set value = ((up_time // divisor) % (mod if mod else divisor)) | int %}
{{- '{} {}'.format(value, name) if value | int > 0 else '' }}
{%- endmacro %}
{%- set values = [
phrase('w', 60*60*24*7),
phrase('d', 60*60*24, 7),
phrase('h', 60*60, 24),
phrase('m', 60),
] | select('!=','') | list %}
{{ values | join(', ') }}
Thanks, and I probably will. I just need another day to process why this takes 12 LOC.
I made the template easily expandable for people who donāt understand code. They can copy the template and remove lines that they donāt want. This could be much shorter and custom, but why bother when this works for all needs/wants
After comparing/contrasting the three example ways to represent the same time at the beginning of this comment, why does:
{{ now() }}
give me this?
2022-05-20 12:37:00.029958-04:00
Which is my local time EDT (UTC-4). So, itās providing me with a local time and the UTC offset which is not a combination that comment suggests is correct (either the time should be 16:37 or the offset should be dropped).
Because I made a mistake in my explanation?
But I think you are right. I should have made that example read:
time (my time zone in UTC representation): 2018-12-14T14:57:27-05:00
Thanks for pointing it out.
