The Haaska Super Thread
Ok, removed the config lines for the haaska,
added this instead -
api:
alexa:
  smart_home:
   filter:
    exclude_entities:
     - switch.laundry_switch
     - switch.hotwater_switch_2
     - remote.family_room
     - switch.family_area_switch
     - switch.family_area_switch_2
     - switch.thanh_s_alexa_apps_do_not_disturb_switch
     - switch.thanh_s_alexa_apps_repeat_switch
     - switch.thanh_s_alexa_apps_shuffle_switch
     - switch.thanh_s_virtual_device_do_not_disturb_switch
     - switch.thanh_s_virtual_device_repeat_switch
     - switch.thanh_s_virtual_device_shuffle_switch
     - switch.this_device_do_not_disturb_switch
     - switch.this_device_repeat_switch
     - switch.this_device_shuffle_switch
     - switch.upstairs_do_not_disturb_switch
     - switch.upstairs_repeat_switch
     - switch.upstairs_shuffle_switch
     - switch.lynn_s_alexa_apps_do_not_disturb_switch
     - switch.lynn_s_alexa_apps_repeat_switch
     - switch.lynn_s_alexa_apps_shuffle_switch
     - switch.home_do_not_disturb_switch
     - switch.home_repeat_switch
     - switch.home_shuffle_switch
     - switch.everywhere_do_not_disturb_switch
     - switch.everywhere_repeat_switch
     - switch.everywhere_shuffle_switch
    include_entities:
     - input_boolean.alexa_server_temp
     - input_boolean.alexa_roof_temp
     - input_boolean.alexa_upstairs_temp
     - input_boolean.alexa_downstairs_temp
     - input_boolean.alexa_kids_temp
     - input_boolean.alexa_house_temp
     - input_boolean.alexa_solar_usage
     - input_boolean.alexa_gate_status
    exclude_domains:
     - automation
     - device_tracker
     - media_player
     - scene
     - script
     - remote
     - binary_sensor
     - sensor
No dice. Still got the same errors :frowning:
I took a look at the code where the failure is occurring and its in the area dealing with thermostats. I don’t know if it is “the” problem or not, but if you have a “climate” entity it could very well be the culprit. If you do, then as suggested earlier, remove your excludes and only include one of your switches and see what happens.
Tommy,
absolute legend :slight_smile: that was it. I DID have a climate entity, once i added it to the excludes list. Presto !
Execution result: succeeded
Thanks for your time looking into this, I really appreciate it
FYI, I see that there was a fix for thermostats in Alexa for 102.2, so may want to upgrade to it and see if your thermostat now works.
Nice . I’ll check it out :+1:
Did you have to do something special to see scenes and scripts in Alexa? I have installed, configured, and tested haaska, I can see lights, switches, and automations, but for some reason I cannot see any scripts or scenes even though I include them specifically in the smart_home section of my configuration file. Any help would be appreciated.
alexa:
  smart_home:
    filter:
      include_domains:
        - light
        - switch
        - script
        - scene
      include_entities:
        - cover.garage_door
        - script.goodnight_script
        - scene.nighttime
        - group.trees
        - automation.alarm_arm_alarm_button_home_mode
        - automation.alarm_arm_alarm_button_away_mode
        - automation.alarm_porch_motion_reset
Never mind - I feel a little dumb. Scenes and Scripts do not show up in the list when you run “discover devices”, but they are indeed available for voice commands.
I’m not entirely sure how the filter works when including both a domain and an entity in the domain.
Would suggest removing the scene and script from the include_domains:, leave the ones in the include_entities:, and see if the ones in the include_entities: showup.
Otherwise your setup looks correct.
Hi all, sorry if someone may notice some double posting on the haaska issue page, but I followed very carefully all the instructions to setup it up and I am hitting the infamous unable to link error.
I have checked every step three times and read a zillion of posts but now I’m lost.
Has anyone managed to make it work “recently” and how?
thanks a lot
[Solved] – I deleted all inside .storage folder and now works on 0.100.3
I need your help, because i had working till yesterday HA 0.100.3 with alexa. Later i decided to update to 0.102.3, and alexa didn’t worked (not discover my HA devices).
With HA v 0.100.3 i had this configuration:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
  latitude: !secret latitude_casa
  longitude: !secret longitude_casa
# Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 88
# metric for Metric, imperial for Imperial
  unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Europe/Madrid
#  customize: !include customize.yaml
  customize: !include_dir_merge_named customized
# Enables the frontend
frontend:
http:
  api_password: !secret http_password
  trusted_networks:
    - 127.0.0.1
    - 192.168.1.0/24
  ip_ban_enabled: true
  login_attempts_threshold: 5
  base_url: https://xxxxxxxx.xxxx.cat:8123
# Configuracion movil
mobile_app:
# Checks for available updates
updater:
# Allows you to issue voice commands from the frontend
#conversation:
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
#logbook:
#Track the sun
sun:
#System Health
system_health:
recorder:
  purge_keep_days: 7
  exclude:
    domains:
      - weblink
      - updater
      - automation
# View Configuration in menu
config:
# Cloud config for Alexa
cloud:
# Discover some devices automatically
discovery:
  ignore:
    - yeelight
#  enable:
#    - homekit
# View Map in menu
map:
#iOs
ios:
#Alexa
alexa_media:
  accounts:
    email: !secret alexa_user
    password: !secret alexa_pass
    url: "amazon.es"
#appleTV
apple_tv:
  - host: 192.168.1.99
    login_id: !secret appletv_login_id
    credentials: !secret appletv_credentials
#homekit
homekit:
  filter:
    include_domains:
      - light
      - cover
      - binary_sensor
      - sensor
      - switch
      - remote
      - script
    include_entities:
      - input_boolean.manuel_casa
      - input_boolean.nastya_casa
panel_iframe:
  netatmo:
    title: 'Calefaccion'
    icon: mdi:radiator
    url: 'https://my.netatmo.com/app/energy'
    #url: 'https://my.netatmo.com/app/therm'
  iconos:
    title: 'Iconos'
    icon: mdi:vector-square
    url: 'https://materialdesignicons.com/'
logger:
  default: warning
  logs:
    homeassistant.components.light.xiaomi_miio: critical
mqtt:
  broker: 192.168.1.100
  port: 1883
  keepalive: 60
telegram_bot:
  platform: polling
  api_key: !secret Telegram_key
  allowed_chat_ids:
    - 78800156
netatmo:
  api_key: !secret netatmo_api_key
  secret_key: !secret netatmo_secret_key
  username: !secret netatmo_username
  password: !secret netatmo_password
  discovery: false
# Example configuration.yaml entry
unifi:
  controllers:
    - host: unifi
      site: My site
      ssid_filter:
        - 'SPIEDERMAN'
        - 'IRONMAN2'
xiaomi_aqara:
  discovery_retry: 10
  gateways:
      key: !secret xiaomi_key
tuya:
  username: !secret tuya_user
  password: !secret tuya_pass
  country_code: 34
  platform: smart_life
#Synology Home Mode
rest_command:
  ss_enable_home:
    url: !secret home_mode_on
    method: get
#    verify_ssl: false
  ss_disable_home:
    url: !secret home_mode_off
    method: get
#    verify_ssl: false
#Configuration for Alexa using haaska
api:
alexa:
  smart_home:
    filter:
      exclude_domains:
        - automation
        - group
        - climate
#        - binary_sensor
        - input_number
        - input_select
        - media_player
        - script
      exclude_entities:
       - input_boolean.alarmstatus
       - input_boolean.alarmsemanapapas
       - input_boolean.alarmsemanasasha
       - input_boolean.alarmstatuspapas
       - input_boolean.alarmstatussasha
       - input_boolean.mute_gateway_xiaomi_sounds
       - sensor.broadlink_sensor_temperature
       - switch.luz_lavadero
       - switch.luz_terraza
       - script.timed_lamp2
       - script.timer_off_nastya
       - script.timer_off_sasha
       - script.timer_off
       - script.play_sel_sound
       - script.timed_lamp_nastya
       - script.timer_lamp_sasha
       - script.timed_lamp
       - script.play_sel_sound_loop
       - script.play_sel_sound_single
Once i updated HA to 0.102.3 i changed these lines:
http:
  trusted_networks:
    - 127.0.0.1
    - 192.168.1.0/24
to these ones:
homeassistant:
  auth_providers:
    - type: trusted_networks
      trusted_networks:
        - 127.0.0.1
        - 192.168.1.0/24
    - type: legacy_api_password
     trusted_users:
       192.168.1.0/24:
         - id_1
         - id_2
       127.0.0.1:
         - id_1
http:
#  api_password: !secret http_password
  base_url: https://xxxxxxxx.xxxxxx.cat:8123
As i detected thtat version 0.102.3 didn’t worked with Alexa, then i returned back to the main configuration, but now, alexa doesn’t discover any device from HA and i dunno what else i need to do.
I unlinked and linked many times haaska skill from Alexa app, and continue the same.
In my logs, i can’t see any connection to alexa…
Someone can help me?
I managed to setup and I have some questions.
So for the first device, I can just say ‘Alexa turn on Living Room Seat Light’ ?
I think I want to change all of these to a simpler name. How do you do it?
Do I need to re-discover again?
Yes you use the name as it appears to control a device. In your case “Living Room Seat Light”.
If you want to use a different name, the easiest (I think) would be to setup a Routine in Alexa. You could as an example setup a routine “Alexa, turn on the Living Room Light” and have Alexa turn on the Living Room Seat Light.
Otherwise you will need to change the configuration in HA and have Alexa do a rediscovery.
You can change the name of the entity, or as an alternative you could add configuration to the alexa: component. Here is an example of the latter:
alexa:
  smart_home:
    endpoint: https://api.amazonalexa.com/v3/events #For the U.S.
    client_id: !secret alexa_client_id
    client_secret: !secret alexa_client_secret
    entity_config:
      switch.kitchen_ceiling_lights:
        description: Kitchen Ceiling Lights
        display_categories: LIGHT
This will show up in Alexa as “Kitchen Lights”.
Is there any way to have haaska upgrade automatically installed like other integration by some tool like HACS?
Hello. Just setup haaska and test was a success. I can see all devices in reply. But after I link the new skill and select to discover devices, none are found.
I googled a lot and also played with languages. Everywhere I can I selected Ireland but I still do not see any devices on my Alexa.
Anyone was in same situation and knows a way to fix this?
Thank you.
hey man im having the same problem, did you manage to find out how to give the alexa an input?
I had the same issue, the problem was wrong aws region.
I have a international version of Amazon Echo (bought from amazon.de). For some reason, the lambda had to be located in us-west-1 region and when set up in there everything worked as expected.
I have the same issue and I’m from France.
@topsy, how do you know that your version is international ? I don’t know if i’ll be able to make it work with us-west-1 and speak french !!
@thehijacker and @kalikeira , did you manage to fix it ?
@fets83 I tried with eu first and didn’t work. In the haaska amazon skill it showed with devUS tag so I decided to give the west-1 a change, and it worked.
Both of my echos were purchased in from amazon.de while my account was years ago created on amazon.com. I had to use us-west-1 as region and all my devices are now found and still working without any issue.
OK so i got everything done and Lambda test worked and returned what it needed to. However my Alexa still wont find my devices. my devices (Echos) are from US amazon and i am on the Lambda N.Virgina. US-East-1
I also tried CA us west 1 but it said i could not it did not support my region. any ideas?
I may have found my problem but dont know the fix. I enabled custom skill that showed up after following setup or i thought. I cant get it to enable it tries and goes right back to enable to use.
Also do i have to do account linking i did not?
