It has nothing to do with this software.
- I completely reinstalled Raspbian using balenaEtcher.
- I connected the Raspberry Pi 4 to a TV via HDMI (relevant?!).
- I logged in with the username
piand passwordraspberry. - I ran
sudo raspi-config. - I selected
1 Change User Passwordand set a new password. - I selected
2 Network Options>N1 Hostnameand set it tohassio. - I selected
2 Network Options>N2 Wi-fiand I entered my Wi-Fi SSID and password. - I selected
5 Interfacing Options>P2 SSHand enabled it. - I selected
Finishand rebooted. - I SSHed into it using
ssh [email protected]and entering the password. - I ran
ifconfig, which printed
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether dc:a6:32:0d:3e:9a txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.111 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::9e53:e5ff:f1bf:c2a prefixlen 64 scopeid 0x20<link>
ether dc:a6:32:0d:3e:9b txqueuelen 1000 (Ethernet)
RX packets 1641 bytes 218905 (213.7 KiB)
TX packets 1134 bytes 106043 (103.5 KiB)
- I ran
sudo reboot. - I ran
ifconfig, which printed the same MAC addresses. - I ran
sudo apt-get update. - I ran
sudo apt-get install network-manager, as it is mentioned in the official guide, which “stopped” at
Setting up modemmanager (1.10.0-1) …
- I ran
ssh [email protected]. - I ran
- inet 192.168.0.111 netmask 255.255.255.0 broadcast 192.168.0.255
+ inet 192.168.0.108 netmask 255.255.255.0 broadcast 192.168.0.255
- inet6 fe80::9e53:e5ff:f1bf:c2a prefixlen 64 scopeid 0x20<link>
+ inet6 fe80::8dc7:e73a:310f:552e prefixlen 64 scopeid 0x20<link>
- ether dc:a6:32:0d:3e:9b txqueuelen 1000 (Ethernet)
+ ether 9e:bd:79:78:5b:b4 txqueuelen 1000 (Ethernet)
- RX packets 1641 bytes 218905 (213.7 KiB)
+ RX packets 17081 bytes 21368136 (20.3 MiB)
- TX packets 1134 bytes 106043 (103.5 KiB)
+ TX packets 7932 bytes 853589 (833.5 KiB)
- I ran
- inet 192.168.0.108 netmask 255.255.255.0 broadcast 192.168.0.255
+ inet 192.168.0.117 netmask 255.255.255.0 broadcast 192.168.0.255
- inet6 fe80::8dc7:e73a:310f:552e prefixlen 64 scopeid 0x20<link>
+ inet6 fe80::2105:7f1:9a1a:147d prefixlen 64 scopeid 0x20<link>
- ether 9e:bd:79:78:5b:b4 txqueuelen 1000 (Ethernet)
+ ether aa:17:35:2b:22:c2 txqueuelen 1000 (Ethernet)
- RX packets 17081 bytes 21368136 (20.3 MiB)
+ RX packets 339 bytes 36629 (35.7 KiB)
- TX packets 7932 bytes 853589 (833.5 KiB)
+ TX packets 316 bytes 45023 (43.9 KiB)
- I ran
sudo systemctl disable ModemManagerandsudo apt-get purge modemmanager(again, from the official guide). - I ran
ifconfig, which printed the same MAC addresses as the last time. - I ran
- inet 192.168.0.117 netmask 255.255.255.0 broadcast 192.168.0.255
+ inet 192.168.0.105 netmask 255.255.255.0 broadcast 192.168.0.255
- inet6 fe80::2105:7f1:9a1a:147d prefixlen 64 scopeid 0x20<link>
+ inet6 fe80::c9fd:f715:6019:afbb prefixlen 64 scopeid 0x20<link>
- ether aa:17:35:2b:22:c2 txqueuelen 1000 (Ethernet)
+ ether 06:a2:2d:bc:4d:84 txqueuelen 1000 (Ethernet)
- RX packets 339 bytes 36629 (35.7 KiB)
+ RX packets 244 bytes 32537 (31.7 KiB)
- TX packets 316 bytes 45023 (43.9 KiB)
+ TX packets 274 bytes 40498 (39.5 KiB)
As you can see, after installing network-manager, the MAC address started to change on every reboot. Exactly like I guessed in the very first comment. The difference was that, the first time, I installed all the required packages at once, installed Home Assistant, set it up, and I didn’t know which exact step caused it.
Now, was there something I did wrong?
Installing Home Assistant using the official guide has nothing to do with Home Assistant?
No, because I do want to
be able to control my host network setup over the UI
Maybe you should ask on the raspbian forums, as this has nothing to do with HA.
I don’t see anywhere where the MAC address changed or you reserved the MAC address in your router.
Also… why do you want to run a server on WiFi?
Screenshot from Installation - Home Assistant.
Because I don’t have any free ethernet port on my router, so I want to connect to it over the Wi-Fi network.
I’d argue that Home Assistant’s instructions should be updated, and I will gladly create a PR for it. Because, as I demonstrated, I followed them and stumbled upon an issue that is not mentioned at all.
And I don’t mean that Home Assistant’s instructions should have an actual solution for it, if it’s not directly related.
But a simple “If you have problems with a Linux distribution that is not mentioned here, please seek help on their official forum” is clearly missing.
This whole exercise if even without HA started, so it has nothing to do with HA. The best help about it is on the raspbian forums, there are the people with much more knowledge about issues like that.
This whole exercise came directly from Installation - Home Assistant.
Then, Installation - Home Assistant should be moved to the Raspbian website.
On that page, I don’t see anything from this exercise.
There is nothing on that page about changing mac-addresses, and it is an issue with network-manager.
Exactly! And that is the issue. That that page isn’t mentioning this issue, caused by installing a package that that page tells you to do.
5 minutes google :
Network-Manager will reset your mac address during the wifi scanning.
To permanently change your mac address:
Edit your /etc/NetworkManager/NetworkManager.conf as follows:
[main]
plugins=ifupdown,keyfile
[ifupdown]
managed=false
[device]
wifi.scan-rand-mac-address=no
[keyfile]
Edit your /etc/network/interfaces by adding the following line:
pre-up ifconfig wlp68s0b1 hw ether xx:xx:xx:yy:yy:yy
The xx:xx:xx:yy:yy:yy is the new mac address obtained from the output of macchanger -A wlp68s0b1
Reboot and verify your settings.
I’m not the only one confused about incomplete documentation:
- https://github.com/home-assistant/supervisor/issues/1488
- https://github.com/home-assistant/hassio-installer/issues/43
And guess what, they’re on Home Assistant’s GitHub repos, not on Raspbian forum.
Do you want to create a PR for this?
I added it: https://github.com/home-assistant/home-assistant.io/pull/12342.
