Would i then not use that in my template ?
going to try…
G
going to try…
G
BINGO
That was it… Really appreciate the assistance…
EDIT: Want to add… people like you… that make this community amazing, thank you.
Final code for the template:
template:
- image:
- name: Garage Tank Level
url: >
{% set input_value = states('sensor.garage_tank_percent') | float %}
{% if 0 < input_value < 2.5 %}
http://172.16.20.19:8123/local/TankLevels0000.jpg
{% elif 2.5 <= input_value < 5 %}
http://172.16.20.19:8123/local/TankLevels0025.jpg
{% elif 5 <= input_value < 7.5 %}
http://172.16.20.19:8123/local/TankLevels0050.jpg
{% elif 7.5 <= input_value < 10 %}
http://172.16.20.19:8123/local/TankLevels0075.jpg
{% elif 10 <= input_value < 12.5 %}
http://172.16.20.19:8123/local/TankLevels0100.jpg
{% elif 12.5 <= input_value < 15 %}
http://172.16.20.19:8123/local/TankLevels0125.jpg
{% elif 15 <= input_value < 17.5 %}
http://172.16.20.19:8123/local/TankLevels0150.jpg
{% elif 17.5 <= input_value < 20 %}
http://172.16.20.19:8123/local/TankLevels0175.jpg
{% elif 20 <= input_value < 22.5 %}
http://172.16.20.19:8123/local/TankLevels0200.jpg
{% elif 22.5 <= input_value < 25 %}
http://172.16.20.19:8123/local/TankLevels0225.jpg
{% elif 25 <= input_value < 27.5 %}
http://172.16.20.19:8123/local/TankLevels0250.jpg
{% elif 27.5 <= input_value < 30 %}
http://172.16.20.19:8123/local/TankLevels0275.jpg
{% elif 30 <= input_value < 32.5 %}
http://172.16.20.19:8123/local/TankLevels0300.jpg
{% elif 32.5 <= input_value < 35 %}
http://172.16.20.19:8123/local/TankLevels0325.jpg
{% elif 35 <= input_value < 37.5 %}
http://172.16.20.19:8123/local/TankLevels0350.jpg
{% elif 37.5 <= input_value < 40 %}
http://172.16.20.19:8123/local/TankLevels0375.jpg
{% elif 40 <= input_value < 42.5 %}
http://172.16.20.19:8123/local/TankLevels0400.jpg
{% elif 42.5 <= input_value < 45 %}
http://172.16.20.19:8123/local/TankLevels0425.jpg
{% elif 45 <= input_value < 47.5 %}
http://172.16.20.19:8123/local/TankLevels0450.jpg
{% elif 47.5 <= input_value < 50 %}
http://172.16.20.19:8123/local/TankLevels0475.jpg
{% elif 50 <= input_value < 52.5 %}
http://172.16.20.19:8123/local/TankLevels0500.jpg
{% elif 52.5 <= input_value < 55 %}
http://172.16.20.19:8123/local/TankLevels0525.jpg
{% elif 55 <= input_value < 57.5 %}
http://172.16.20.19:8123/local/TankLevels0550.jpg
{% elif 57.5 <= input_value < 60 %}
http://172.16.20.19:8123/local/TankLevels0575.jpg
{% elif 60 <= input_value < 62.5 %}
http://172.16.20.19:8123/local/TankLevels0600.jpg
{% elif 62.5 <= input_value < 65 %}
http://172.16.20.19:8123/local/TankLevels0625.jpg
{% elif 65 <= input_value < 67.5 %}
http://172.16.20.19:8123/local/TankLevels0650.jpg
{% elif 67.5 <= input_value < 70 %}
http://172.16.20.19:8123/local/TankLevels0675.jpg
{% elif 70 <= input_value < 72.5 %}
http://172.16.20.19:8123/local/TankLevels0700.jpg
{% elif 72.5 <= input_value < 75 %}
http://172.16.20.19:8123/local/TankLevels0725.jpg
{% elif 75 <= input_value < 77.5 %}
http://172.16.20.19:8123/local/TankLevels0750.jpg
{% elif 77.5 <= input_value < 80 %}
http://172.16.20.19:8123/local/TankLevels0775.jpg
{% elif 80 <= input_value < 82.5 %}
http://172.16.20.19:8123/local/TankLevels0800.jpg
{% elif 82.5 <= input_value < 85 %}
http://172.16.20.19:8123/local/TankLevels0825.jpg
{% elif 85 <= input_value < 87.5 %}
http://172.16.20.19:8123/local/TankLevels0850.jpg
{% elif 87.5 <= input_value < 90 %}
http://172.16.20.19:8123/local/TankLevels0875.jpg
{% elif 90 <= input_value < 92.5 %}
http://172.16.20.19:8123/local/TankLevels0900.jpg
{% elif 92.5 <= input_value < 95 %}
http://172.16.20.19:8123/local/TankLevels0925.jpg
{% elif 95 <= input_value < 97.5 %}
http://172.16.20.19:8123/local/TankLevels0950.jpg
{% elif 97.5 <= input_value <= 100 %}
http://172.16.20.19:8123/local/TankLevels0975.jpg
{% else %}
http://172.16.20.19:8123/local/TankLevels1000.jpg
{% endif %}
And Dashboard
type: vertical-stack
cards:
- show_state: false
show_name: false
camera_view: auto
entity: image.garage_tank_level
type: picture-entity
- type: entities
entities:
- entity: sensor.garage_tank_litre
- entity: sensor.garage_tank_cm
name: Water Level (Cm)
- entity: sensor.garage_tank_percent
name: Fill Percentage
- entity: sensor.garage_tank_last_update
name: " Last Reading"
And Visual:
G
One further thing, have you tested this outside your local network?
The image integration appears to use a proxy but I’m not 100% sure.
yes, just disconnected from my network and access HA… all working
It seems HA paints the picture itself and then sends that to the client app.
Have 2 tanks to do… the 3rd sensor (0-10bar) is a water line/booster pump, so will think about how to display that one.
For now the logic’s there, so can work on improving the image further.
G
totally off topic… now to go back onto the app that pull these values, the posting to mqtt working fine… as we are displaying here.
The app also posts into InfluxDB… and the logs show the values going in…
and a select on the DB shows the values, but for one or other reason neither Grafana or kapacitor want to show the data… it actually shows the database and a measurement set is present and the fields, just done of the data.
Sunday Fun… and it was working previously
G
tanking chance, I drew this water tank in draw.io.
just giving back… how/where can I upload. even tried to rename to .txt, but seems app is bit cleverer…
G
If you zip up the file you should be able to drag and drop it in a post.
Nope, it immediately shows me formats supported and zip is not one…
Will GIT the project quickly and then post the repo link here…
[GitHub - georgelza/waterlevel: Python code to read 2 types of transducer water level sensors.](https://Project that measures water levels in tank via Transducers & displays via HA Dashboard/Template)
See TankLevels for the jpg images and the draw.io source file.
Please check/confirm you can get to project and the draw.io file
G
If the tank level is 0, your template outputs the full image — and that’s the only value that results in the full image. I think you want 0<=
and <100
rather than 0<
and <=100
If you are interested, the whole template can be reduced to this, which gives the empty image for 0 and the full image for 100:
url: >
{{ 'http://172.16.20.19:8123/local/TankLevels%04d.jpg' % (input_value*10//25*25) }}
thanks.
Will give it a go.
G
