Thanks for mentioning the broken link, fix is on the way.
As for the auto-discovery - auto-discovery is turned off after 30 minutes of the initial start up to prevent auto-discovered and added devices which might just pass your house or are activated at your neighbours.
Once you get new devices which you want added through auto-discovery you can switch it back on until they are all added then turn it off again to prevent the above.
reset the plug with a long press of the button or the following Home Assistant command ( available from Settings ā Devices & Services ā Devices - Enter TPLUG)
Reconnect to the WiFi portal and enter the new MQTT broker
hey thanks. I did end up doing a hard reset and that is fine.
I did first try to sent the command. not sure why that didnāt work. It published ok. and showed up (I was watching it on mqtt-explorer); then went dead for maybe 15 seconds, and then started back up using the original broker; presumably reverting to the last working settings.
It seemed like it never tried to contact the new broker (but, come to think of it, i donāt know that for sure)
(EDITED to add: Thinking back, I think I had taken it upon myself to change mqtt_auth to true, which wouldnāt be correct for my installation; and that was probably why it failed)
I found the issue, seems that this device advertise different lengths of servicedata (these are the data used for decoding) and we were taking into account only the larger ones.
If you are interested, you can send me by PM an email and I can provide you a test binary.
Iām not surprised that itās something specific to this device as the Theengs plug has picked up all my other relevant devices with ease
Would I need to leave auto discovery on for a while in hopes of it capturing the needed service data?
Other thoughts:
The plug is in the basement monitoring the energy used by the washing machine and I put it there because I have a smartdry in the dryer right next to it. The device Iām asking about is on the main floor. I wonder if there could be a range issue with the device (not the plug as it picks up devices on the 2nd floor without issue). I could possibly use a different plug on the washer and move my Theengs to a more centralized location, but only if it would still pick up the smartdry.
I will do a range test with this particular device but I think this is related to a change of MUE4094RT firmware. I will send you a test one for the Theengs plug to confirm.
Hi there ā i just got a couple of Govee GVH5105ās thermometersā¦
I see them in MQTT explorer, e.g.:
{āidā:āC3:38:30:33:2E:37ā,āmac_typeā:1,āadv_typeā:0,ānameā:āGVH5105_2E37ā,āmanufacturerdataā:ā01000101043b3d64ā,ārssiā:-82}
But they arenāt showing up in HA.
The last time i had this problem when i added some switchbot thermometers, my problem was I didnāt have SYS: Auto Discovery turned on.
So this time, I made sure to turn it on but no new Goveeās are appearing in HA.
