Do you have a line that starts with a :
Make sure you have the latest version of card-tools and please provide the new error message if it still happens.
No, but I did have a bunch of comments that were included in the theme code.
I just tried it again with most (not all) of the comments pared out and it isnāt giving the error anymore. So for some reason it doesnāt seem to like having any content before the first theme element?
So this wonāt work:
## https://www.colorhexa.com/
color_chart:
# Main Stuff #
primary-color: "#848482" # Grey
light-primary-color: "#ff1493" # Pink
primary-background-color: "#89cff0" # Baby Blue
secondary-background-color: "#bf94e4" # Lavendar
#ha-card-background:
paper-card-background-color: "#915b25" # Brown
paper-item-icon-color: "#ff4f00" # Orange
but this is OK:
color_chart:
# Main Stuff #
Then on the second one itās able to strip out all of the comments and leave only the code.
Installed version 0.4 and the error persists:
2019-07-29 10:24:08 ERROR (MainThread) [frontend.js.latest.201907211] http://192.168.1.2:8123/local/card-tools.js?:53:20 Uncaught TypeError: Cannot read property 'querySelector' of null
Clear your cache in all browsers: https://github.com/thomasloven/hass-config/wiki/Lovelace-Plugins#clearing-cache
That did the trick, sorry for not seeing your FAQ!
Should this still be working with most recent hassio version?
Iāve got installed lateatcard-tools and have read the faq bit canāt get it to work.
Only need to know if it should still be working. Iāll have to mess around to figure out so I can learn
It should still work.
I did get it to work half eventually
Import/export not working but at least i can try out some live theme changes
Import suddently stopped working for me after the latest patch update.
Iāve updated my plugin, cleared the cache, tried different themes.
I think this is the relevant log from chromeās console.
dumper.js:756 Uncaught (in promise) i {name: "YAMLException", reason: "unacceptable kind of an object to dump [object HTMLElement]", mark: undefined, message: "unacceptable kind of an object to dump [object HTMLElement]", stack: "YAMLException: unacceptable kind of an object to dā¦cal:8123/frontend_latest/app.2d1ab8ac.js:2:12900)"}mark: undefinedmessage: "unacceptable kind of an object to dump [object HTMLElement]"name: "YAMLException"reason: "unacceptable kind of an object to dump [object HTMLElement]"stack: "YAMLException: unacceptable kind of an object to dump [object HTMLElement]āµ at Z (https://hassio.local:8123/frontend_latest/chunk.076aaca62db3e8acde76.js:2417:193326)āµ at ee (https://hassio.local:8123/frontend_latest/chunk.076aaca62db3e8acde76.js:2417:193917)āµ at e.exports.safeDump (https://hassio.local:8123/frontend_latest/chunk.076aaca62db3e8acde76.js:2417:194005)āµ at HTMLElement.value (https://hassio.local:8123/frontend_latest/chunk.076aaca62db3e8acde76.js:2503:32)āµ at HTMLElement.update (https://hassio.local:8123/frontend_latest/app.2d1ab8ac.js:2:17467)āµ at HTMLElement.performUpdate (https://hassio.local:8123/frontend_latest/app.2d1ab8ac.js:2:13270)āµ at HTMLElement._enqueueUpdate (https://hassio.local:8123/frontend_latest/app.2d1ab8ac.js:2:12900)"__proto__: Errorconstructor: Ę i(e,t)toString: Ę (e)__proto__: Object
_enqueueUpdate @ updating-element.js:469
async function (async)
_enqueueUpdate @ updating-element.js:446
_requestUpdate @ updating-element.js:413
initialize @ updating-element.js:268
initialize @ lit-element.js:95
O @ updating-element.js:98
V @ lit-element.js:46
F @ hui-error-card.ts:29
(anonymous) @ VM758:1
u @ card-mod.js:1
p @ card-mod.js:1
(anonymous) @ card-mod.js:1
create @ card-mod.js:1
setConfig @ card-mod.js:1
set config @ card-mod.js:1
S @ card-tools.js:1
yamlMode @ theme-maker.js:153
handleEvent @ parts.js:434
__boundHandleEvent @ parts.js:400
Ah, rightā¦
ā¦forgot about that thingā¦
Thereās a new version on github that fixes this.
Iām shocked I got the right log
Thanks! This also seems to have been my problem.
Fully working theme-maker now.
Great addition to messing with Home Assistanyt for me, just like your other works!
Iām having trouble getting this to work. Iām sure I probably just overlooked something, but when I try and create a manual card in lovelace and put:
type: custom: theme-maker
Iām getting the error:
Custom element doesn't exist: theme-maker.
type: 'custom:theme-maker'
I installed card-tools from HACS. I cloned the theme-maker github and placed the theme-maker.js into /config/www/js/theme-maker.js
This is my resources information from the raw config editor:
resources:
- type: module
url: /community_plugin/lovelace-card-tools/card-tools.js
- type: js
url: /local/js/theme-maker.js?v=1
I see nothing in the logs related to this and Iāve restarted hassio, cleared cache, refreshed, etc.
Any ideas what Iām doing wrong?
The see this guide
link in the readme contains some troubleshooting tips that may help you get more information.
I cannot import a theme. I am not able to click anywhere in the popup. Everything else is working wonderfully. Any advice?
hello. this tool keep maintened?
Unfortunately I have the same problem, have you managed to solve it?
No, I hardly ever used the card.
