It needs an entity and possibly attribute to track. You should create an input number helper entity so the slider has something to track, and then create an automation to set the input number back to 0 when the timer ends.
This is the code from the slider:
type: slider
entity_id: number.zhimi_zb1a_a860_countdown_time
range:
- 0
- 8
tap_action:
action: perform-action
perform_action: number.set_value
value: β{{ value | float }}β
step: 1
unit_of_measurement: h
icon: mdi:clock-outline
value_attribute: min
label: Heating Schedule
haptics: true
styles: ββ
state: null
State is not a valid field and value_attribute should not be set since youβre tracking the entity state.
type: slider
tap_action:
step: 1
range:
- 0
- 8
haptics: true
If youβre on the latest version of custom features, you should be able to do all of this using the configuration UI and not have to touch YAML anymore.
