Did you read the link in post #6? What you posted above is unreadable for debugging purposes. Spaces are critical to the format.
Open the ESPHome tab then click on “Edit” in the device. When you are editing the configuration code, select all then copy to clipboard. In the forum, start a post and click on the </> icon at the top. Then paste your code in the message body where prompted. This preserves the indentation of YAML code. If it isn’t properly indented, we can’t efficiently read the code.
did exactly as Instructed. If I reboot or remove the power from the pi the HA is on everything work properly. Which make me believe that the problem is with wifi router and d1min not connecting quick enough. It also pass the validate.
did exactly as instructed to up load my yaml. Shutting down the pi or restarting HA ever thing works fine, but when there is a loss of power to the whole house it doesn’t .
And now did an update to ESPHome and now can not update the d1mim oat.Went back and restored from back up fix that issue.
If you had done it correctly then it would look like this:
esphome:
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "RsveWB6pJa72QSBcf08G7wgVJRm9idmX+VIXyzDOQmA="
ota:
password: "e38d3ee526ecc0aec7d8fcd1c98a20ac"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "David-Remote Fallback Hotspot"
password: "cIHaBV9Kv5xC"
captive_portal:
binary_sensor:
- platform: gpio
pin: GPIO5
name: "David TV on/off"
light:
- platform: neopixelbus
type: GRB
variant: WS2811
pin: GPIO9
num_leds: 8
name: "David TV front light"
internal: true
- platform: partition
name: "David TV front light Partition Light 1"
segments:
# Use first 10 LEDs from the light with ID light1
- id: light1
to: 1
See how there is spaces on the left of some words?
That shows that you did not copy the code from the ESP-Home editor. You (again) just copied the code you pasted in post 14, right?
Looking at the screenshot you posted before, we can see that there are spaces. But you didn’t copy from there.
So… No, you did not do as instructed.
When the ESP device has a power loss it will reboot and return to the state it was programmed to have at boot.
Most likely that is a low output on the pin that controls the relay.
