24 set to Send Notification if status is changed manually or remotely.
Here’s what should be the log for a “failure”. Switched it on and it went off again:
2019-12-12 18:40:25.578 Detail, Node006, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x06, 0x0a, 0x32, 0x02, 0x21, 0x74, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x82
2019-12-12 18:40:25.578 Detail, Node006, Refreshed Value: old value=false, new value=false, type=bool
2019-12-12 18:40:25.578 Detail, Node006, Changes to this value are not verified
2019-12-12 18:40:25.578 Info, Node006, Received Meter report from node 6: Power=0.000W
2019-12-12 18:40:25.578 Detail, Node006, Refreshed Value: old value=0.000, new value=0.000, type=decimal
2019-12-12 18:40:25.578 Detail, Node006, Notification: ValueChanged
2019-12-12 18:40:25.581 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-12-12 18:40:25.586 Detail, Node006, Notification: ValueChanged
2019-12-12 18:40:29.059 Info, Node006, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2019-12-12 18:40:29.060 Info, Node006, SwitchBinary::Set - Setting node 6 to On
2019-12-12 18:40:29.060 Detail, Node006, Queuing (Send) SwitchBinaryCmd_Set (Node=6): 0x01, 0x0a, 0x00, 0x13, 0x06, 0x03, 0x25, 0x01, 0xff, 0x25, 0x3b, 0x26
2019-12-12 18:40:29.060 Detail, Node006, Queuing (Send) SwitchBinaryCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x25, 0x02, 0x25, 0x3c, 0xdf
2019-12-12 18:40:29.060 Info, Node006, Sending (Send) message (Callback ID=0x3b, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=6): 0x01, 0x0a, 0x00, 0x13, 0x06, 0x03, 0x25, 0x01, 0xff, 0x25, 0x3b, 0x26
2019-12-12 18:40:29.276 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-12-12 18:40:29.277 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2019-12-12 18:40:29.330 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x3b, 0x00, 0x00, 0x06, 0xd6
2019-12-12 18:40:29.330 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x3b received (expected 0x3b)
2019-12-12 18:40:29.330 Info, Node006, Request RTT 269 Average Request RTT 181
2019-12-12 18:40:29.330 Detail, Expected callbackId was received
2019-12-12 18:40:29.330 Detail, Expected reply was received
2019-12-12 18:40:29.331 Detail, Message transaction complete
2019-12-12 18:40:29.331 Detail, Node006, Removing current message
2019-12-12 18:40:29.332 Info, Node006, Sending (Send) message (Callback ID=0x3c, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x25, 0x02, 0x25, 0x3c, 0xdf
2019-12-12 18:40:29.344 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-12-12 18:40:29.344 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2019-12-12 18:40:29.574 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x3c, 0x00, 0x00, 0x18, 0xcf
2019-12-12 18:40:29.574 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x3c received (expected 0x3c)
2019-12-12 18:40:29.575 Info, Node006, Request RTT 242 Average Request RTT 211
2019-12-12 18:40:29.575 Detail, Expected callbackId was received
2019-12-12 18:40:33.574 Detail, Node006, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x06, 0x0a, 0x32, 0x02, 0x21, 0x74, 0x00, 0x00, 0x03, 0x54, 0x00, 0x00, 0xd5
2019-12-12 18:40:33.575 Info, Node006, Response RTT 4242 Average Response RTT 2209
2019-12-12 18:40:33.575 Detail, Node006, Refreshed Value: old value=false, new value=false, type=bool
2019-12-12 18:40:33.575 Detail, Node006, Changes to this value are not verified
2019-12-12 18:40:33.575 Info, Node006, Received Meter report from node 6: Power=0.852W
2019-12-12 18:40:33.575 Detail, Node006, Refreshed Value: old value=0.000, new value=0.852, type=decimal
2019-12-12 18:40:33.575 Detail, Node006, Notification: ValueChanged
2019-12-12 18:40:33.579 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-12-12 18:40:33.583 Detail, Node006, Notification: ValueChanged
