This action requires a security code, but it hasn't been set up in your device's app
Google does not even ask me for my secure pin?
FYI the whole PIN code not working thing seems to be an issue for everyone right now w/ Google Assistant. see here: https://support.google.com/googlenest/thread/32447767?hl=en
Chime in with your issue as well so they see it I suppose!
Looks like this is part of the Configuration UI now… at least if you’re using Nabu Casa. Go to Configuration > Home Assistant Cloud > Google Assistant, and look for “Security Devices”. I put a PIN in there and I can tell Google to open/close everything again. Good luck!
Sorry to necro an old thread, but is there still no way to natively disable the pin (i.e., allow unlocking or opening without a pin)? Is this a limitation on the HA or Google side?
So I figured this out by going to Settings > Home Assistant Cloud > Google Assistant and doing the following
  1. Enter a security pin
  2. Go to Manage entities and disable 2 factor authentication everywhere you do not want to be asked for a pin.
