This automation cannot be edited from the UI, because it is not stored in the automations.yaml file, or doesn’t have an ID.
A search leads to this comment but I have automations.yaml within my configuration (and are only using automations.yaml, not splitting it up) and all of my automations have unique ids generated originally by HA (except for the below one that apparently needed to have a unique ID generated).
I just use the standard structure for my configuration:
I tried to migrate it and deleted it from the yaml afterwards (I duplicated it to get a “clean” version before that).
After I deleted it in the automations.yaml, it was still active somewhere behind the scenes (and not visible in the UI nor the yaml).
I was also able to find it in Developer tools in States as an automation entity and set it to OFF.
However, after a while it came back to ON, so I switched it back to OFF.
It’s annoying and I don’t know how to get rid of it.
Check the actual automations.yaml file from e.g. notepad or another text editor. I have experience duplicates of an automation, resulting in strange behavior. Check if the automation is actually 2 times in automation.yaml.
So far the only thing I have noticed is that in chrome both on my windows desktop and macbook I’m getting this error. However the same automation loads fine for me on safari and edge.
Thanks for this tip! I just started getting this error yesterday after I upgraded HA. I’m running HAOS on an rpi 4.
My versions
Home Assistant 2023.8.2
Supervisor 2023.08.1
Operating System 10.4
Frontend 20230802.0 - latest
I’d file a bug report, but I have to go to work to work on software bugs there, lol.
Update: it seems to be working in Google Chrome now. I’m not sure what fixed it ,but around the same time HA stopped working in Chrome, my self-hosted web sites started getting flagged as “dangerous” and “deceptive” in Google Chrome.
Just happened to me. Automation suddenly started saying they needed migration.
The moment I tried to migrate one the letsencrypt TLS certificate stopped working, an alternative browser than Chrome was required to accept the new self signed certificate to access the web ui.
I’ve had this happen randomly a couple of times - usually after I’ve suspended my virtual machine by savings its state, and then restoring the running machine. (More often that not because the host machine needed to be restarted after an update to something or other).
Every time the issue has occurred, fully shutting down the HA instance and rebooting from scratch fixed it - with no changes to automations.yaml
I have the same problem from about 20 days. Before, all was ok.
I have tried re-generate all ids with vscode (ex: - id: b73a2081-d933-4f6b-84a1-4af0849cd13e) and I’ve checked that all automations had an id.
Nothing
I also experienced this problem today. Like @pcal said it may have something to do with hibernating the PC, waking up in another network, …
I run the HA interface in an MS Edge application on Windows 10. After hard-refreshing the app (ctrl-R) the error disappeared and I could edit the automations again.
Hope this is useful information for others who experience this problem…
I also encountered this issue today. Also happened after restoring from saved state of my virtual machine. Funny thing is I can login with remote access, but can’t login locally. Unfortunately complete shutdown HA didn’t solve the problem. As David pointed out, it’s caused by ip_bans.yaml. I found my local IP is listed in ip_bans.yaml for unknown reason. After removing the local IP in ip_bans.yaml and restart HA, it’s back to normal.
