That’s weird.
As “it was working” and now isn’t (and given the complete reboots) it sounds like “something” literally changed the time zone of the OS.
What time zone do you live in ?
@petro sorry M8 you will probably be be better suited to help here, I’ve never come across an issue like this.
exactly, I don’t understand why suddenly it’s acting weird since yesterday. I live in India (+5:30 IST)
I’ve also checked my router (Xiaomi 3C) time and it was way back to 2018 and it’s synced now (no effects on hassio).
@petro really helped me with error logs, but couldn’t find anything in related with date & time.
Wanted to try fresh installation, but don’t want to admit my defeat.
Ok, I’m stumped. I don’t see how the integration can be not-working but also not produce warning, error, or debug statements saying why it’s not working.
As a side note, the system time does not depend on this integration. It just takes the system time and gives uses a sensor to display/use the time. So looking at logger page times and times in other areas has no bearing on the integration.
After you point out those "ERROR"s, I’ve checked them all and cleared them. Now I’m not getting anything like ERROR (all upper case - assuming them major errors). But I have many “Errors”(with lower case letters) with many integration that I don’t use or never heard them and not checked them all as they’re more than 600 results in search. I’ll take some time and check them. It must be logged somewhere buried in that.
They are probably python errors. which is what we are looking for. I don’t recall if you’ve said this, but are you running Hassio or home assistant in venv?
unbelievable! It FIXED ITSELF just like that. I don’t know how! Time and date both are correct. It’s a bit cheerful and disappointment as I don’t know what’s wrong before.
Just checking log file in Config folder and observed it’s size is big and too many similar logs and wanted to restart to check logs from start. After that it shows right time.
Don’t know what fixed this time. But I’ve observed few logs I haven’t noticed before. Searched with term “time_date” but I don’t recall I’ve seen below logs before.
Should I require info level logs? I mean, they are pretty common for all systems and don’t need our attention right? Just wanted to reduce my SD card wear level.
