Exactly the same. But just setting the timezone in settings wasn’t enough. Had to restart the server.
Now it’s solved as well
has this officially been fixed?
I have exactly the same problem. Time zone is correct, I even changed it to another city, did not work either. dev tools now() states the correct time and I have restarted HA various times.
The holiday sensor works properly, I use it in other automations with sunrise and that works like a charm.
This is my automation. It works with sunrise, but not with time
Any ideas?
alias: Cover Up Weekday
description: ''
- platform: time
at: '8:00:00'
condition:
- condition: state
entity_id: binary_sensor.holiday
state: 'off'
- device_id: 3230cfb2f23ff6ed08771ca482d95e62
domain: cover
entity_id: cover.covername
type: set_position
position: 100
mode: single
Shouldn’t be the reason, but have you tried 08:00
Yes I did, in fact it was ‘08:00:00’ before - same result: not working
I was running HA OS in a VM in VirtualBox onDdebian. I moved the VM to a windows host (of all things) and my time issues went away.
I think it was relatve to the somfy integration. I moved to the Tahoma integration and it is working ever since. I must say it did work also with Somfy (I moved the time from 08:00:00 to 08:01:01 and it worked, but I also learned that the official Somfy integration is struggling sometimes, unless it is reloaded - I just moved to Tahoma and I also left the time-trigger at 08:01:01 and its all working ever since.
I’ve resolved my issue by setting up the timezone correcty in the UI:
http://homeassistant:8123 → Settings → System → General
I first restored a backup I made when a clean install, and then changed the timezone as above, then configured the automation. All worked after doing that.
I know this is an old thread but I setup some new automations about 4-5 months ago and realized that none of them are triggering. Two days ago I decided to add an additional trigger of going off every X number of hours. Still nothing. My time zone is set correctly. Any other ideas?
alias: HVAC Filter Needs Cleaned - Chore
description: ""
- platform: time
at: "18:00:00"
- platform: time_pattern
hours: "23"
condition:
- condition: template
value_template: " value_template: \"{{ as_timestamp(now()) > (as_timestamp(states('input_datetime.cleaned_hvac_filter_chore')) + 15552000) }}\""
data: {}
entity_id:
- input_boolean.hvac_filter_needs_cleaned_chore
- service: notify.mobile_app_iphone_wf4l1910mh
message: Clean HVAC Filter
- service: notify.mobile_app_iphone_12
message: HVAC Filter Needs Cleaned
mode: single
You’ll probably find errors in your logs, as that condition is nonsense. I suspect you want:
value_template: "{{ as_timestamp(now()) > (as_timestamp(states('input_datetime.cleaned_hvac_filter_chore')) + 15552000) }}"
Your time pattern trigger will not fire every 23 hours: it will fire at 23:00 only. See the documentation.
