Still not sure why you are jumping through all these hoops when you can do this:
That method won’t work if it’s over 60 minutes. His method does.
Ah, so that is a limitation for more than just the time pattern trigger. Seems to be an unjustified limit here.
I might be wrong… You might be right… I’d need to do tests. You can quickly figure this out if you put in 61 minutes and the yaml complains at you.
I think you are correct, I don’t think there’s a limitation. So yeah, your for template should work fine. I’ll let you know in 70 minutes.
The following config was accepted as valid:
- alias: 'Workshop Lights Auto Off'
- platform: state
entity_id: binary_sensor.pir_workshop
to: 'off'
for:
minutes: 61
Yeah, I’m running one right now with 70 minutes
Times up!
What happened?
Oh I forgot and reset my container…
Hi everyone, sorry for the delay.
I’ve tried the following code but it does not work for any value above 60 minutes
- id: cf063a3a5d984cb7a3bc85d225b0a5b0
alias: Bathroom ventilation timer
description: ''
- entity_id: fan.bathroom_ventilation
for:
minutes: '{{ states(''input_number.bathroom_ventilation_timer'') }}'
platform: state
to: 'on'
condition: []
- data: {}
service: homeassistant.turn_off
mode: single
