I have noticed on 2024.1 that if a condition is set be it, if it is CHOOSE or IF, the timer that comes with it isnt working. Like if i set to to notify me after 10 secs, the script does nothing. If i remove the timer, it works fine… Anyone else?
Post the automation or script that contains the problem.
Ensure it’s posted as formatted YAML.
alias: door checks
description: Check the door state and send a notfication
- platform: state
entity_id:
- binary_sensor.garage_door_sensor_open
- binary_sensor.front_door_sensor_open
- binary_sensor.outdoor_garage_sensor_open
- binary_sensor.back_door_sensor_open
to: null
for:
hours: 0
minutes: 0
seconds: 0
- condition: trigger
id:
- "0909"
- alias: Check Back Door
if:
- condition: state
entity_id: binary_sensor.back_door_sensor_open
state: "on"
for:
hours: 0
minutes: 0
seconds: 15
then:
- service: notify.notify
metadata: {}
message: The back door has been opened for over 15 seconds
title: Back Door Notification
- alias: Check garage door
if:
- condition: state
entity_id: binary_sensor.garage_door_sensor_open
for:
hours: 0
minutes: 0
seconds: 10
state: "on"
then:
metadata: {}
message: Garage Door has been opened for over 10 seconds
title: Garage Door Notification
- if:
- condition: state
entity_id: binary_sensor.outdoor_garage_sensor_open
state: "on"
for:
hours: 0
minutes: 10
seconds: 0
then:
metadata: {}
message: The Garage door has been opened for over 10 minutes
alias: Check Main Garage Door
- alias: Check Front Door
if:
- condition: state
entity_id: binary_sensor.front_door_sensor_open
state: "on"
for:
hours: 0
minutes: 0
seconds: 10
then:
metadata: {}
message: The front door has been opened for over 10 seconds
title: Front Door Notification
- stop: Checked all doors
trace:
stored_traces: 12
mode: restart
If i remove the timer or set it to 0, it works, and instantly as expected
In Home Assistant, this is a timer
I believe what you call “timer” is the State Condition’s for
option.
The reason why it works when you remove the for
option, or set it to 0, is because you’re failing to understand how the automation you created actually works.
You designed the automation to trigger at the instant when any of four doors is opened (or closed). Then you check if the door was open for at least 10 or 15 seconds (depending on which door). It cannot possibly be open for that much time because it just opened microseconds ago.
Effectively, you created this:
When the door opens, check it has been open for at least the past 10 seconds.
It cannot be “open for the past 10 seconds” because it just opened a fraction of second earlier.
I suggest you move the for
option into the State Trigger.
Example
alias: door checks
- platform: state
entity_id:
to: 'on'
for:
seconds: 10
- platform: state
entity_id:
to: 'on'
for:
seconds: 15
condition: []
- variables:
door: "{{ trigger.to_state.name }}"
metadata: {}
message: 'The {{ door | lower }} has been opened for over {{ trigger.for.seconds }} seconds'
title: '{{ door }} Notification'
mode: queued
Thanks very much I will give it a try and report back
Works great Taras … Thank you very much. Actually, you are right! what you stated above is what i tried to do. It was my mistake
