Love it. Spouse approval is so necessary!
Feel free to post your automation in here just in case anyone is looking for exactly that.
Im sure this could be cleaned up a bit but here’s my automation. It sends a notification to my wife and i as well as plays a sound over our kitchen speakers. This is for whole minute timers which is our only use case currently. Will start/stop/pause/restart a single timer.
alias: Auto Timer
description: ""
- platform: conversation
command:
- (cancel|stop|end|pause|restart) timer
- (start|set) (a) timer (to|for) {timer_time} minute[s]
- platform: homeassistant
event: start
- platform: event
event_type: timer.cancelled
- platform: event
event_type: timer.finished
condition: []
- choose:
- conditions:
- condition: trigger
id:
- command
sequence:
- variables:
command: "{{ trigger.sentence.split(' ')[0] | lower }}"
tenbelow:
ten: 10
nine: 9
eight: 8
seven: 7
six: 6
five: 5
four: 4
three: 3
two: 2
one: 1
- choose:
- conditions:
- condition: template
value_template: "{{ command in ('start', 'set') }}"
sequence:
- if:
value_template: >-
{{ trigger.slots.timer_time | trim | lower in tenbelow
then:
- service: timer.start
duration: "{{ tenbelow[trigger.slots.timer_time] * 60 }}"
entity_id: timer.timer1
else:
duration: "{{ trigger.slots.timer_time | int(0) * 60 }}"
- service: tts.speak
metadata: {}
cache: true
media_player_entity_id: media_player.the_kitchen
message: "{{trigger.slots.timer_time}} minute timer started."
entity_id: tts.piper
- conditions:
value_template: "{{ command in ('cancel', 'stop', 'end', 'pause', 'restart') }}"
sequence:
- variables:
response_command: |-
{%- if command in ('cancel', 'stop', 'end') -%}
cancel
{%- elif command == 'pause' -%}
pause
{%- elif command == 'restart' -%}
start
{%- endif -%}
response_word: |-
cancelled
paused
restarted
{%- endif -%}
enabled: true
- service: timer.{{ response_command }}
- if:
value_template: "{{ command == 'cancel' }}"
then:
- service: timer.stop
metadata: {}
cache: true
message: >-
Timer {{ response_word }}.
- conditions:
id:
- finished
sequence:
- service: media_player.play_media
media_content_id: media-source://media_source/local/timer.mp3
media_content_type: audio/mpeg
metadata:
title: timer.mp3
thumbnail: null
media_class: music
children_media_class: null
navigateIds:
- media_content_type: app
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- service: media_player.media_pause
metadata: {}
data: {}
metadata: {}
cache: false
message: Timer Finished.
enabled: true
metadata: {}
cache: false
media_player_entity_id: media_player.master_bedroom
enabled: true
- service: notify.parents
title: Timer!
- conditions:
id:
- cancelled
sequence:
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
metadata: {}
cache: false
message: Timer Cancelled.
metadata: {}
cache: false
title: Timer!
mode: single
Thanks. I am sure it will help some folks down the road!
You certainly have some clever stuff in there
Great job!
And just like that i screwed the automation up and cant figure out what the heck is going on. I’ll need to look at this when my kids arent being terrorists.
Something in here is wrong:
duration: >-
{{ tenbelow[(trigger.slots.timer_time | trim | lower)] |int * 60 }}
Added a default to int and then it just outputted “5,5,5,5,5…” 60 times. Somethings going on with the dictionary lookup. Should be an integer but it seems as though its still being converted to a string.
Take the quotes off of your setting of tenbelow. it is a string right now.
Nice catch. I ended up redoing it a bit and was able to just use one variable up a few levels. I’ll update the code here in a second after i do a few more tests.
Edit: Updated!
I’m curious if anyone has gotten this working recently. I have all of the constituent parts up and running, when I ask assist to do anything with a timer, it says no timers are available. I believe this is due to the standard timer vocabulary, which, I’m guessing did not exist when this script was built?
First, you are correct, HA timers did not exist when I created this.
I don’t really have a use for this. It was fun to create back when I did it. I do know it worked before HA added it themselves as I tested it extensively.
Is it really needed now? If you pull it all out, does the HA timer stuff meet your needs?
Can the HA timer stuff be turned off? I don’t know.
I couldn’t get the built in timer functionality to work, at least not triggered by willow, but your project, in spirit, guided me to my own solution, or at least the start of a solution. Thanks!
Glad it helped!
