To Proxmox or not to Proxmox
Hi @jacekk015 , I have the same t630 with Proxmox installed. But I have issues installing HomeAssistant VM. I’m always getting “TASK ERROR: KVM virtualisation configured, but not available. Either disable in VM configuration …”. The BIOS is up-to-date (v1.17). I also checked that the Virtualization is Active in the BIOS (enabled). Do you have any clue what I’m doing wrong?
greetings and thanks,
André
According to:
guys are sometimes playing with TPM setting.
You have newer BIOS version than me.
if the error-message says that ‘KVM virtualisation configured, but not available’ then the system does not see the virtualisation as enabled.
Don’t disable KVM on the VM in Proxmox - performance will be low!
There’s a screen on Polish site about installing HA on Proxmox:
https://hejdom.pl/blog/22-home-assistant/434-home-assistant-sprzet-hp-t630.html
Direct image link:
DEP and VT enabled
https://hejdom.pl/dodaj-zdjecia/image.raw?view=image&type=orig&id=4231
