No worries, whenever you get time. Here’s the error it’s generating:
Error while setting up platform todoist
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/urllib3/connectionpool.py”, line 601, in urlopen
chunked=chunked)
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/urllib3/connectionpool.py”, line 346, in _make_request
self._validate_conn(conn)
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/urllib3/connectionpool.py”, line 850, in validate_conn
conn.connect()
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/urllib3/connection.py”, line 326, in connect
ssl_context=context)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/urllib3/util/ssl.py", line 329, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/ssl.py”, line 377, in wrap_socket
_context=self)
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/ssl.py”, line 752, in init
self.do_handshake()
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/ssl.py”, line 988, in do_handshake
self._sslobj.do_handshake()
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/ssl.py”, line 633, in do_handshake
ssl.SSLError: [SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:645)
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/requests/adapters.py”, line 440, in send
timeout=timeout
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/urllib3/connectionpool.py”, line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/urllib3/util/retry.py”, line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘todoist.com’, port=443): Max retries exceeded with url: /API/v7/sync (Caused by SSLError(SSLError(1, ‘[SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:645)’),))
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py”, line 170, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/tasks.py”, line 392, in wait_for
return fut.result()
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/futures.py”, line 274, in result
raise self._exception
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/components/calendar/todoist.py”, line 127, in setup_platform
api.sync()
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/todoist/api.py”, line 318, in sync
response = self._post(‘sync’, data=post_data)
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/todoist/api.py”, line 291, in _post
response = self.session.post(url + call, **kwargs)
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/requests/sessions.py”, line 555, in post
return self.request(‘POST’, url, data=data, json=json, **kwargs)
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/requests/sessions.py”, line 508, in request
resp = self.send(prep, **send_kwargs)
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/requests/sessions.py”, line 618, in send
r = adapter.send(request, **kwargs)
File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/requests/adapters.py”, line 506, in send
