Tomorrow.io hourly has stopped working
this is super weird
I’m clearly targeting hourly:
- name: Weatherman Data
      state: "OK"
      attributes:
        weather_condition_0: >
          {% set cond0 = hourly["weather.tomorrow_io_home_hourly"].forecast[0].condition %}
          {% set next_setting = as_timestamp(state_attr('sun.sun', 'next_setting')) %}
          {% set next_rising = as_timestamp(state_attr('sun.sun', 'next_rising')) %}
          {% set cond0_time = as_timestamp(hourly["weather.tomorrow_io_home_hourly"].forecast[0].datetime) %}
          {% if ( cond0_time < next_rising and next_rising < next_setting ) or ( cond0_time > next_setting and cond0_time < next_rising ) %}
              {% if cond0 == 'sunny' or 'clear-night' %} night {% elif cond0 == 'partlycloudy' %} night-partly-cloudy {% else %} {{ cond0 }} {% endif %}
          {% else %}
              {{ cond0 }}
          {% endif %}
        weather_temperature_0: >
          {{ hourly["weather.tomorrow_io_home_hourly"].forecast[0].temperature | round }}
        weather_timestamp_0: >
          {{ as_timestamp(hourly["weather.tomorrow_io_home_hourly"].forecast[0].datetime) | timestamp_custom('%I')
It is weird indeed. I do not see anything wrong with your code. What if you swap the actions and do hourly last and dayly first? If that changes things (it shouldn’t) then it would point to a bug where the second service calls internally replaces the data from the first call.
swapping the order didnt change anything. But neither did commenting out the daily service, then the hourly and then both altogether. :thinking:
And now I’m not receiving anything at all which leads me to believe the attributes were somehow pulled elsewhere from a wonky file config or something.
Will update if I figure it out!
Do yourself a favor and reduce your overhead by using variables. Also, You don’t need to get the daily information every hour. Separate that out.
e.g.
- trigger:
    - platform: time_pattern
      hours: /1
      - variables:
          entity: weather.tomorrow_io_home_hourly
      - service: weather.get_forecasts
          type: hourly
          entity_id: "{{ entity }}"
        response_variable: hourly
      - variables:
          mapped:
            sunny: night
            clear-night: night
            partlycloudy: night-partly-cloudy
          info: >
            {%- set ns = namespace(items=[]) %}
            {%- set sunrise = state_attr('sun.sun', 'next_setting') %}
            {%- set sunset = state_attr('sun.sun', 'next_rising') %}
            {%- for hour in hourly[entity] if loop.index < 4 %}
              {%- set cond = hour.condition %}
              {%- set t = hour.datetime | as_datetime | as_local %}
              {%- set tod = t.strftime('%I%p') %}
              {%- set temp = hour.temperature | round %}
              {%- set ret = mapped.get(cond, cond) if (t < sunrise and sunrise < sunset) or (sunset < t < sunrise) else cond %}
              {%- set ns.items = ns.items + [dict(cond=ret, tod=tod, temp=temp)] %}
            {%- endfor %}
            {{ ns.items }}
      device_class: timestamp
      state: "{{ now() }}"
      attributes:
        weather_condition_0: "{{ info[0].cond }}"
        weather_temperature_0: "{{ info[0].tod }}"
        weather_timestamp_0: "{{ info[0].temp }}"
        weather_condition_1: "{{ info[1].cond }}"
        weather_temperature_1: "{{ info[1].tod }}"
        weather_timestamp_1: "{{ info[1].temp }}"
        weather_condition_2: "{{ info[2].cond }}"
        weather_temperature_2: "{{ info[2].tod }}"
        weather_timestamp_2: "{{ info[2].temp }}"
        weather_condition_3: "{{ info[3].cond }}"
        weather_temperature_3: "{{ info[3].tod }}"
        weather_timestamp_3: "{{ info[3].temp }}"
You can also turn this into a script to debug the output in the scripts trace.
get_weather_info:
  sequence:
      - variables:
          type: hourly
      - variables:
          mapped:
            sunny: night
            clear-night: night
          info: >
            {%- endfor %}
            {{ ns.items }}
      - stop: End the script
        response_variable: info
Then using it in your template entity…
- trigger:
      hours: /1
      - service: script.get_weather_info
      attributes:
Thanks Petro. Is this a solution to my current issue? For now I’m just looking for this code to work, however shabby it might be than to learn new things like using variables and creating scripts. I will come back to that though.
Edit: As for separating daily and hourly out, ofc that makes sense but here I am making a comparison of daily temps to hourly and if hourly goes higher than daily high or lower than daily low then that is adjusted since it would be odd if an hourly low temp is lower than the daily. I believe I wouldnt be able to read from the response variable in a different block
I realise my current issue is using this trigger in my templates.yaml file where a trigger should be in automations?
configuration.yaml:
edit: maybe not but it must be how the files are set up for my weatherman data to now be empty
Triggers can be used in both automations and templates.
You can copy/paste the code I wrote and it’ll do what you want. It’s a direct replacement for what you’ve shown.
Thank you :pray:
creating a new file with only
- trigger:
      minutes: /1
      - variables:
          type: hourly
      - variables:
          mapped:
            sunny: night
            clear-night: night
          info: >
            {%- endfor %}
            {{ ns.items }}
      attributes:
and I’m still not being returned any data (attributes)
Make the script I said above and view the trace
