Dear All, did you find a workaround to get it working ?
Thank you
Thank you
Anybody got it back to work? I want to setup HA and i have a boxx
hi all, just did the beta upgrade to 2022.09 and the integration works again.
itās a different log-in page (electrabel) but was able to log in and i have al the sensors back.
I donāt know, if itās on any help to our southern neigbors, but here in Holland we had an issue with Eneco Toon also. It did not connect anymore.
The solution for us were:
So, thatās, how we solved our problem. I hope it will help you out. But things can be different for youā¦
hello, whould I put an universal address other then this one? Link to OAuth2 Authorize Callback ā My Home Assistant
thanks for your help
https://my.home-assistant.io/redirect/oauth
works fine.
Hi jasjerpke iĀ“m new to HA and want to link my boxx from engie. Can you assist me how you did this?
It worked fine for a while with the generic universal https://my.home-assistant.io/redirect/oauth
URL,
itās broken again for me on 2022-11-02
edit : must have been a temporary issue, because it came back after an hour or so
Invalid response from API: Timeout occurred while connecting to the Quby ToonAPI; Retrying in background
Check, if your mobile does connect. It can be a problem with the Toon server.
I think that was it, something temporary. It came back after an hour or so.
Hi all,
Iām trying to connect my Boxx to HA.
I made an Develop account on Toon and HA found the new Toon integration.
When I want to configure the integration, I get this error:
{"fault":{"faultstring":"Invalid ApiKey","detail":{"errorcode":"oauth.v2.InvalidApiKey"}}}
Anyone has an idea what Iām doing wrong?
Didnāt copy the whole key
