I do not have the possibility or authorization to publish a new version with the hotfix. Only @DurgNomis-drol can do that.
But be warned, the current version with the hotfix has lost some of its functionality in preparation for major changes!
We are also currently in the process of rewriting the mytoyota Python lib, on which the custom component is based, to the new API endpoints. However, this is a major undertaking:
Perhaps @DurgNomis-drol would like to wait with the release of a new version until this preliminary work has been completed and a custom component based on the new mytoyota API endpoints can be created.
Fully understood. I´d be happy to help testing! I´m thinking if it would be helpful to have this as a separate repository (for those migrated to the new Toyota app) which allows to use this beta version or have it as a development branch in HACS to test.
Worst case logically I can copy the code manually and help testing, but having it available through HACS would just simplify and you can go back to older versions easily if needed.
Thanks @DurgNomis-drol! Did you already post the new code as beta master? It does not seem to work yet. Don´t want to complain or put pressure. Just would like to help if I can.
Thanks. I’ve got it loaded and although initially it did not connect now it does and I do get limited data so perfect. Looking forward to help testing if needed.
Version 2.0.0 of the toyota Custom Component now includes all customizations for the new Toyota oneapi!
This also means that this version is no longer compatible with your vehicle if you are still using the old MyT app! Before updating, please make sure that you are already using the new MyToyota app and that your vehicle has already been migrated to the new API.
The changes may not look big to you in terms of the Home Assistant sensors and entities, but there have been huge changes in the background!
Especially due to the great support of @GitOldGrumpy and @CM000n , there were more than 50,000 lines of code changed in the mytoyota Python Lib and the ha_toyota Home Assistant Custom Component to ensure compatibility with the new Toyota API.
But of course, as the initiator of the two projects, we should not forget to mention @DurgNomis-drol.
All these changes make it necessary for you to completely remove the previous Custom Component installation from your Home Assistant devices and HACS!
You should then perform a reboot and can then reinstall the custom component via HACS again.
The old project is currently still offered in HACS. But we are working on it and a pull request is already open to replace the old project with the new one in HACS.
Hi, Thanks for the project you have implemented. I own a C-HR+ and I installed Toyota Connect in Home Assistant. It would be great to develop dashboards and access data such average electric consumption for the last trip, for the last 1000km or 5000km. Having those datas for the last 20 trips would be useful
