Has anyone managed to get a KC100 working with Scrypted? I have 1 KC105 and 4 KC100 no issues getting the KC105 up and running but I get an authentication error with all of the KC100. Using the same string for all of them just updating the ip address.
Okā¦ sooo deep breath.
I got scrypted working with a KC200ā¦ youāre going to want to hold on for this wild journey.
Some of the kasa cameras wonāt take the username and password as part of the URLā¦
Soā¦
You have to take your password and base64 encode it Base64 Encode and Decode - Online
Then you take your username and the base64 encoded password - put a : in between them and base 64 encode the entire thing
As an example letās say my username is [email protected]
and my password is Password1!
Base 64 encode the password gets you UGFzc3dvcmQxIQ==
So then you base 64 encode [email protected]:UGFzc3dvcmQxIQ==
and you get dXNlckB0ZXN0LmNvbTpVR0Z6YzNkdmNtUXhJUT09
- this is your authentication token
Then the input stream arguments should be
-headers "Authorization: Basic dXNlckB0ZXN0LmNvbTpVR0Z6YzNkdmNtUXhJUT09" -f h264 -i https://192.168.1.206:19443/https/stream/mixed?video=h264&audio=g711&resolution=hd
Note that you need quotes around the entire Authentication: Basic xxxxxx
part
Good luck
Confirming this worked for the KC100 and KC105 also. Thanks!
I have a KC410S. This guide was a super quick way to get the camera stream up and running. However, I am only receiving snapshots from the camera and cannot get a stream. I opened the rtsp stream in VLC on my computer and it seems to be working fine. In scrypted I can see that the motion detection state is changing as well. Both the stream in scrypted and HomeKit are only showing snapshots when the page is reloaded/home app is opened. I just got the camera today so Iām sure I have more fiddling to do. Any tips would be greatly appreciated!
Ok I figured out why my KC400 wasnāt working. Everything was loading fine but not video or jpeg.
When setting up HA add-on in the config= camera nameā¦ everything must be lowercase, I had one capital for Camera.
Also saw in post that someone had a Kasa watermark, one can turn that off in the Kasa app setting for camera.
Sooo Cheers to me!!
I can confirm this works with the KC410S And EC70, but I only get video, no sound, in HomeKit.
Here is my arguments:
-f h264 -i https://<user>:<pass>@<i.p address>:19443/https/stream/mixed?video=h264&audio=g711&resolution=hd
Is there anything else I need to set up to get sound?
I have a EC70 and none of these seem to work, I cannot get it to authenticate. Did something change in firmware to nerf this solution?
Could you give an example of what you did to add 3 cameras, please and thank you!
Does this addon still work?
When I try to add the repository through supervisor I get the following error:
Cmd('git') failed due to: exit code(128) cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/joshgetter/hassio-addons/tree/master/kasa-camera /data/addons/git/7247aaf7 stderr: 'Cloning into '/data/addons/git/7247aaf7'... fatal: repository 'https://github.com/joshgetter/hassio-addons/tree/master/kasa-camera/' not found '
the url I am copying is: https://github.com/joshgetter/hassio-addons
Am I doing something wrong?
Thanks.
I know youāve been waiting awhile, I hope you got an answer elsewhere. Here is what I did based on this post:
Went to Settings, Add-ons, Add-on Store. At the top right I clicked the ā¦ Repositories and added it as https://github.com/joshgetter/hassio-addons
Then it showed Hass.io
Add-ons - Josh Getter and showed Kasa Camera and Node-RED.
I installed Kasa Camera, started it, added my cameras to the config. Then I added local file camera integration (search for it, I canāt post links) and added a Camera card to the dashboard, set the URL to the http://<HA IP>:43330/thumbnails/<CAMERA NAME>.jpg
Good luck!
do you have step by step instruction how to make it. im spand week and nothing works. thanks
Posting here in case this helps someone:
- Settings > Addons > Add-on Store > 3 buttons top right corner > add GitHub - joshgetter/hassio-addons: A Home Assistant Addon repository.
- Refresh > Click Kasa Camera > Install > Populate configuration with your kasa email & password, camera name & camera IP > save > click start on the info tab (the log tab should show āKasaStreamer.HealthChecker[0]ā with ā IS healthyā)
- My dashboard auto-added a card for the camera, and asked me to specify still image URL & stream source URL.
You can manually do this by clicking Setings > Devices & Services > Devices tab > Add device > search āGeneric Cameraā. For Still image URL use:
For stream source URL use:
http://<HA IP>:43330/hls/<CAMERA NAME>.m3u8
(for both make sure to use IP address of HA, not the camera IP)
- Select HTTP for RTSP transport protocol, and basic as the authentication. Leave username & password blank & uncheck verify SSL certifcate.
Now I can see my kasa EC70 camera right on home assist. Thanks Josh Getter for making this possible.
