TP-Link Omada Integration in 2023.3
Home Assistant added in today’s release 2023.3 the TP-Link Omada Integration. It doesn’t do much yet, but I would like to test it out anyways.
I get the following error in the credentials dialog:
Logger: homeassistant.components.tplink_omada.config_flow
Source: components/tplink_omada/config_flow.py:91
Integration: TP-Link Omada (documentation, issues)
First occurred: 14:36:51 (4 occurrences)
Last logged: 14:43:40
Unexpected API error: 192.168.1.2/api/info
Unexpected API error: Omada controller responded 'Unexpected error: 0, message=‘Attempt to decode JSON with unexpected mimetype: text/html;charset=utf-8’, url=URL('https://192.168.1.2/d1bda887d7464099a7edd5aed9518621/login’)’ (0)
I can’t add the Integration because of this. Did someone manage to add it?
Before someone asks: I do have a local Omada Controller (OC200).
You might also check this thread:
Thank you!!
I will just follow the thread you mentioned.
