Hi! I have a tapo P110 plug and someone know how the plug receive wifi credential from the tapo app ?
Thanks!
Have you installed the Tapo_p100 integration? I followed all instructions in https://github.com/petretiandrea/home-assistant-tapo-p100 and have had my P110 working flawlessly for several months.
Pretty sure it remains cloud based, so you need to add the device to the Tapo app and then add the config to the HA Tapo integration.
I might have noticed that if you hit the eye to show the password, then submit, it seems to work, else same error?
Can confirm this has been working well with my P100s
Update: This question has been withdrawn. I used a different way to get it working. Please see my second post.
I followed the guide from @jon.g from above.
Password is changed to 8 chars with one number and one capital letter.
Both devices are switched on, both are getting the fixed IP as intended from the router.
In the āTapoā App on the phone I can switch them on/off as desired.
However, something is wrong and not working for the two P100 that I have (HW Version 1.20.0, Firmware 1.2.10 Build 20210207 Rel 67438)
The devices are not showing up in HA in Device or Entities (no hit fro search of āp100ā).
Any ideas, what I need to change?
Here is the log from HA:
Logger: homeassistant.components.switch
Source: custom_components/tapo_p100_control/switch.py:83
Integration: Schalter (documentation, issues)
First occurred: 22:31:33 (2 occurrences)
Last logged: 22:31:33
Error while setting up tapo_p100_control platform for switch
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 281, in _async_setup_platform
await asyncio.shield(task)
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/config/custom_components/tapo_p100_control/switch.py", line 44, in setup_platform
add_entities([P100Plug(p100)])
File "/config/custom_components/tapo_p100_control/switch.py", line 53, in __init__
self.update()
File "/config/custom_components/tapo_p100_control/switch.py", line 83, in update
self._p100.handshake()
File "/usr/local/lib/python3.10/site-packages/PyP100/PyP100.py", line 124, in handshake
encryptedKey = r.json()["result"]["key"]
KeyError: 'result'
Ok, I followed the hints from @Britespark above and used the UI configuration in the linked video.
Now both P100 are recognized, and I can switch them by HA.
I happened to have the same issue. Have you resolved yours?
Cheers!
Same problemā¦ invalid authentication ā¦
Hi All - Sorry in advance that this comment is going to be a bit useless in terms of collected info - Last night I updated the Tapo integration in HACS - Iām confused as to how I was about 5 versions behind, as I update everything in Home Assistant all the time - Itās possible that whatever HACS uses to generate a notification in the HA UI, wasnāt working though, although I had updated some other integrations within the last week. I did the update for Tapo, and for another number of HACS integrations, and following this, I lost all energy monitoring of my P110 sockets. At least two of my Tapo bulbs are not responding quite correctly either - I can sometimes control them directly (via HA) , but when used in a Scene, they are now not working as before. I have four Tapo bulbs in my living room, and have a number of scenes set for these - two bulbs are still working, but two are now not. Sorry Iāve not compiled any bulb model/version debug info etc. but posting up in case anyone else has had this issue since the last update. Iām fighting a bad flu/cold at the moment, so will try and share some actual useful info as soon as I can. I did have something like this before, at least 6 months ago, and I think it cleared on the next update. Iām running around 11 Tapo bulbs, 4 P100 sockets and maybe 13 P110 sockets - the sockets (both P100 and P110) are operating in terms of switching on and off, but the power monitoring has gone.
The 5 versions came out in rapid succession as the first was a bit buggy.
For the power monitoring, the update has created a new entity and is using that.
Note the name of your current entity, delete it and use the old name for the new entity.
This way you should have to change any automations or cards.
I donāt have any of the bulbs or P100ās so canāt help there sorry.
Hiya Darren - thanks very very much for this thatās unlocked it for me - it looks like the old entity was ācurrent energyā and it is now ācurrent powerā (albeit with some underscores and dots etc. ) In my case, Iām using the Grafana plugin with innodb , so Iāll go look for the new entities there - I can see them now (new and old (old being āunavailableā)) in the main lovelace interface too - I might have worked it out myself, given a few weeks Really appreciate your help, thanks - Iāll have to come back to the bulb issue, but itās restricted to one room at the moment, and where Iām in the house by myself for a few days, Iāll hopefully be feeling back to normal and try and work that one out, and post up here what I find
Hi all, unfortunately I still have all the TAPO devices with errors, and I canāt add new ones, even after the update:
old device:
2023-01-03 15:07:00.216 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Server' for tapo integration not ready yet: Unexpected exception: unexpected character: line 1 column 1 (char 0); Retrying in background
2023-01-03 15:07:00.218 ERROR (MainThread) [custom_components.tapo.common_setup] Failed to setup Unexpected exception: unexpected character: line 1 column 1 (char 0)
when i try to add a new device:
2023-01-03 22:25:01.959 ERROR (MainThread) [custom_components.tapo.config_flow] Failed to setup cannot connect
all my notifications are based on P100s or lights, so HA is unusable for me unfortunately
Hi All, a bit more info, this only seems to be affecting the following combination for me:
Model: Tapo L530B (B22/Bayonet Lightbulb)
Hardware Version: 2.0
Firmware Version: Build 220526 Rel.203202
It does seem to work if you control the bulbs separately via the default HA controls, but they default to being āredā in the controls, but actually light up in a lower brightness than normal.
I control all my bulbs with scenes, but when you set them in a scene, save the scene, and return to the scenes menu, the lights listed above, turn off.
I need to work through the other bulbs to see if these are still working normally.
Iām waiting for some more power monitoring P110 plugs to arrive, and if they do in time, Iāll try and add them as a new device, to see if I can replicate milleniumy2kās issues .
Even with the latest version released yesterday, the integration always presents the same errors:
2023-01-09 10:21:46 2023-01-09 10:21:46.965 ERROR (MainThread) [custom_components.tapo.common_setup] Failed to setup Unexpected exception: unexpected character: line 1 column 1 (char 0)
Hi All, the latest updates have resolved my issues, so all bulbs and power sockets (in versions and hardware models that I have) are all working correctly now. I did have two updates to home assistant core though, and I think one of the release notes in that mentioned about fixing an issue which may have actually been the problem, so not specifically the Tapo integration (apologies if this was the case) - I should have tried the updates a bit more methodically, to see which one actually resolved it, but have been rushing with work Am still waiting on my latest batch of Tapo plugs to arrive, but will report what happens when I try to add new devices when I do
Hi All, the latest update (jan 17) seemed to have caused the reverse of my previous issues - following the update, when a bulb is triggered by an automation to go on, I set the brightness in the scene to be maximum - when the older of my L530 bulbs now go on (hardware version 1) the go bright (expected) then within a second, drop down to a half or third brightness. The newer bulbs (hardware version 2) do not seem to be affected so far. sorry for the lack of info again, itās been a long day
i have one P100 and yes, it works. Look for Tapo Controller integration in HACS.
You also should assign a static ip to your plug
Installed the integration through HACS and it worked perfectly with my p100. Thank you!
How did you end up fixing the 1003 error?
Does anyone know how to fix āmigration errorā on P100?
How I got here:
- P100 switches were unavailable
- I upgraded the integration to the latest version
- all but one switch is reporting āmigration errorā
Error:
Logger: homeassistant.config_entries
Source: config_entries.py:650
First occurred: 11:16:13 (5 occurrences)
Last logged: 11:16:13
Error migrating entry Stekkerblok kantoor for tapo
Error migrating entry Aanrecht for tapo
Error migrating entry Koelkast for tapo
Error migrating entry TV en aanverwanten for tapo
Error migrating entry Vaatwasser for tapo
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 980, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore[return-value] # noqa
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1085, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1069, in create_connection
sock = await self._connect_sock(
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 973, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 628, in sock_connect
return await fut
File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 668, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('192.168.2.137', 80)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 650, in async_migrate
result = await component.async_migrate_entry(hass, self)
File "/config/custom_components/tapo/__init__.py", line 59, in async_migrate_entry
await migrate_entry_to_v6(hass, config_entry)
File "/config/custom_components/tapo/migrations.py", line 18, in migrate_entry_to_v6
api = await connect_tapo_client(
File "/config/custom_components/tapo/setup_helpers.py", line 99, in connect_tapo_client
await api.initialize()
File "/usr/local/lib/python3.11/site-packages/plugp100/api/tapo_client.py", line 62, in initialize
await self._guess_protocol()
File "/usr/local/lib/python3.11/site-packages/plugp100/api/tapo_client.py", line 218, in _guess_protocol
response = await self.execute_raw_request(
File "/usr/local/lib/python3.11/site-packages/plugp100/api/tapo_client.py", line 71, in execute_raw_request
return (await self._protocol.send_request(request)).map(lambda x: x.result)
File "/usr/local/lib/python3.11/site-packages/plugp100/protocol/passthrough_protocol.py", line 42, in send_request
response = await self._send_request(request)
File "/usr/local/lib/python3.11/site-packages/plugp100/protocol/passthrough_protocol.py", line 62, in _send_request
await self._login_with_version(self._credential)
File "/usr/local/lib/python3.11/site-packages/plugp100/protocol/passthrough_protocol.py", line 81, in _login_with_version
session_or_error = await self._passthrough.handshake(self._url)
File "/usr/local/lib/python3.11/site-packages/plugp100/protocol/securepassthrough_transport.py", line 70, in handshake
response = await self._http.async_make_post(url, json=request_body)
File "/usr/local/lib/python3.11/site-packages/plugp100/common/utils/http_client.py", line 18, in async_make_post
async with self.session.post(
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 1141, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 536, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 540, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 901, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 1209, in _create_direct_connection
raise last_exc
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 1178, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 988, in _wrap_create_connection
raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host 192.168.2.137:80 ssl:default [Connect call failed ('192.168.2.137', 80)]
