- alias: sensor.galo_pir turn_on light.hall_light motion_detected
platform: state
entity_id: sensor.hall_pir
to: 'ON'
condition:
condition: state
entity_id: sun.sun
state: below_horizon
service: homeassistant.turn_on
entity_id: light.hall_light
transition: 4
brightness: 180
Here’s a little script you can use instead of light.turn_on. It uses half of the given time to first transition the brightness, afterwards it changes the color_temp in half of the given time:
alias: Tradfri_Transition
fields:
entity_id:
description: Name(s) of the IKEA Tradfri entities
example: light.panel
transition:
description: >-
The time in seconds it should take until the desired state is fully
reached
example: 60
brightness:
description: The desired brightness between 0..255
example: 142
color_temp:
description: The desired color temperature in mireds
example: 311
sequence:
- service: light.turn_on
data_template:
entity_id: '{{ entity_id }}'
brightness: '{{ brightness | int }}'
transition: '{{ transition | int / 2 }}'
- delay: '00:00:{{ transition | int / 2 + 1}}'
data_template:
color_temp: '{{ color_temp | int }}'
mode: single
Here’s a sample call:
service: script.tradfri_transition
entity_id: light.panel
color_temp: 436
transition: 60
brightness: 26
So whenever you switch on one or more Tradfri lights just use the script as service instead of light.turn_on.
I’m having issues with Tradfri and transitions as well. I have tried activating scenes with a transition in the automation. I have tried putting the transition directly into scripts, and now I put the transition back in an automation, but without using scenes. Nothing seems to work.
By separating the temperature and brightness it works better. Let’s say you want the bulb to slowly dim and get warmer. Try making the bulb first transition one of the two attributes, and then the other.
Still, it’s not reliable at all for me. I have two Tradfri bulbs. Sometimes only one bulb transitions, sometimes none of them do. Sometimes one of them transitions to a warmer state but does not dim, the other dims but does not get warmer. The total randomness of it made me suspect noise was the issue, as i had the Conbee II connected directly into the pi. I added an extension cord without success.
I’m all out of ideas really.
EDIT: Just activating bulbs and scenes without transition work though. So Transition (or maybe automation) seems to be the issue.
Some of my tradfri bulbs have issue with not beeing able to use transitions and set wanted brightness, the way i made it work is to first send a “turn_on” to the problematic bulb first, and then the scene with the transition.
(scene includes that same problematic bulb)
It seem that some of the bulbs needs to be turned on before it can recive and understand the transition and brightness data.
Automation
entity_id: light.living_room_corner_hallway
- service: scene.turn_on
entity_id: scene.pre_watch_movie
transition: 2.5
Scene
- id: c6298787-c935-497b-83b3-1fa5ccfc7b65
entities:
light.hallway_mirror:
state: 'off'
light.hallway_wardrobe:
state: 'on'
light.living_room_window:
state: 'on'
brightness: 29
light.living_room_corner_hallway:
state: 'on'
brightness: 35
Thanks for this. Using homeassistant.turn_on rather than light.turn_on seems to be working
What should I do if I am trying to get the light to dim up on a curve?
