What’s that condition for?
It should only trigger when the calendar appointment include the word <åbendør>
Did you have another calendar event overlapping at the same time?
See examples here Calendar - Home Assistant
I would suggest using trigger data instead of the entity state
no i dont have
I have now created a spec. calendar in googlecalendar.yaml and it seems to work.
I thought I could do it from UI
Yes you can do this via conditions in the trigger data as described in the example automations Calendar - Home Assistant
(Search can’t handle overlapping events and has caveats and doesn’t work on all calendars so I don’t recommend it generally, but glad you have a solution)
Is this broken now. I’ve just noticed my two calendars that i created using search are not appearing in HA any more.
No, shouldn’t be broken. Feel free to file a GitHub issue with more details and we can investigate your issue.
Thank you. I found my issue. I was trying to update one of my searches a few weeks ago to use multiple terms.
search:
- cleaner
- house clean
I didn’t notice at the time but this is not compatible and causes it to be ignored and a new default entry to be created for the top level calendar.
Fixed now.
search: cleaner
